Old 06-15-2021, 03:43 PM
audioluche audioluche is offline
Default PCI adaptor for 2019 Mac Pro
I am looking for options for my audio drives in my mac pro 2019.
I may go for a Sonnet M2 4x4 card, but i am wondering, if i want to put only one drive on a PCI adaptor, except the OWC Accelsior, is there any adaptor that works well in the new mac pro? I am having problems finding the right one with the right specs (PCI 4 a must?).
Anyone willing to share their experiences?
Thanks!
Luc
Old 06-15-2021, 03:59 PM
LukeHoward LukeHoward is offline
Default Re: PCI adaptor for 2019 Mac Pro
The Mac Pro 2019 is PCIe 3.0, not 4.0, if that's what you are asking?
https://lukehoward.com/
Old 06-15-2021, 04:10 PM
Yes and no!
Well, i tought the Mac Pro had PCI 4.0 slots, so you just put me on the right track!
I guess i mix up PCI 4.0 and PCI 4x.
So any PCI 3.0 adaptor should work fine?
Thanks!
Old 06-15-2021, 04:22 PM
Yes, PCIe 3.0, see below
https://support.apple.com/en-au/HT210104
Old 06-16-2021, 03:20 AM
dominicperry dominicperry is online now
I won't recommend anything personally, but this is a common topic on the MacRumors forum, where there are lots of video guys who need massive storage, massive speed and considerable reliability. It's worth checking out, and bear in mind that using Catalina or Big Sur makes a difference, as the EFI firmware gets updated and that means the drive enclosures need updated software/firmware too.
Try these as a start:
https://forums.macrumors.com/threads...rsion.2232133/
https://forums.macrumors.com/threads...g-sur.2268207/
https://forums.macrumors.com/threads...speed.2298625/
https://forums.macrumors.com/threads...lades.2222397/
https://forums.macrumors.com/threads...osure.2218751/
https://forums.macrumors.com/threads...eltec.2219976/
Big Thread https://forums.macrumors.com/threads...c-pro.2189591/
My personal feeling with the two main players - OWC and Sonnet - is that Sonnet stuff is more reliable and better supported, but I don't have extensive experience.
Dominic
Old 06-16-2021, 04:33 AM
Marsdy Marsdy is offline
Originally Posted by audioluche View Post
Thanks!
Luc
If you just need one drive then there are plenty of x4 cards that work fine. Basically they just wire the NVMe drive directly to the PCIe bus.
I use one of these with a new Mac Pro
https://www.amazon.co.uk/Computer-kr...ustomerReviews
It has good cooling built in, no need to add a heat sink.
I also have the Sonnet 4x4. It’s a no brainer, especially since the latest version is fanless.
The only other contender IMO is the OWC card but that is 8x so you’re not getting the full speed out of four NVMe drives.
I looked into other options but they all have downsides, like really difficult firmware upgrade procedures or very noisy fans. Cards like the Highpoint and Amfeltech. This may have changed in the year since I looked into this though.
Dave Marsden
UK
Old 06-17-2021, 11:56 AM
Thanks!
Old 06-17-2021, 11:57 AM
Dominic
Thanks for all that, i've got some reading to do!
Old 06-17-2021, 12:02 PM
Thanks Marsdy.
Yes, i think i will go with the Sonnet 4x4 in the future, but if i put a drive on a PCI card, does it need the heatsink?
Because if i put the heatsink with some gel on it, then, i wont be able to remove the drive(s) from the card(s) when i purchase the sonnet and want to move my drive(s) on the sonnet?
I wonder if the heatsink is really needed?
Did you put one in your system?
Thanks!
Old 06-17-2021, 03:06 PM
Thanks Marsdy.
Thanks!
The card I linked to - the Aqua Computer kryoM.2 evo PCIe 3.0 x 4 has cooling/heatsinks built in and also comes with stick on thermal pads, not paste that are removable/reversible. It’s very solidly built. Unlike most other cards there are heat sinks on both sides of the NVMe drive.
I use it with a Samsung Evo which runs at the same temperature as the Samsungs on my Sonnet 4x4. Whenever I look, it’s the exact same temperature in iStat menus.
Ideally you do need cooling of some sort otherwise you risk the drive thermal throttling at best and at worst it failing.
Dave Marsden
UK
HDX Ultimate - 2019.10 7 2019.12 - video export issues anguswoodhead Post - Surround - Video 2 03-09-2020 02:33 AM
Pro Tools 2019.12 Ultimate Crashes 2019 Mac Pro rmccam Pro Tools 2019 11 02-28-2020 03:59 AM
Workspace Borked 2019.10 and 2019.12 KMcK Pro Tools 2019 0 01-17-2020 02:09 PM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 08:12 AM
VST to RTAS Adaptor vs. ReWire to RTAS Adaptor TriAxis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-22-2004 10:28 PM
