Old 06-14-2021, 08:40 AM
martthie_08 martthie_08 is offline
Default D-Command with Trinnov D-Mon?
Been thinking about investing in a Trinnov D-Mon for my second mix room. I have a trusty blue D-Command with ATC speakers hooked up to it.
Does anyone have this setup and is willing to share some experience?
I currently use X-Mon for monitor control and this would probably get replaced if I understand correctly? I don't need talkback but would like to have two or ideally three stereo input sources and a headphone feed, currently have a Lake People headphone amp hooked up CUE1 on the X-Mon for that.
Old 06-22-2021, 03:54 AM
Default Re: D-Command with Trinnov D-Mon?
the main thing I'd be interested to find out is how well the integration is with the controls on the d-command, i.e. does dim / mute work, can I change input sources with the dedicated switches? thanks!
Old 09-22-2021, 07:30 AM
francois's Avatar
francois francois is offline
Works here like it should.
The only caveat I have is my talkback mic being very distorted since an update of the Trinnov firmware but I'm still not 100% sure if it's coming from it.
PT 2021-7 ultimate -HDX1- OSX 10.15.7- MacPro 7.1
- D-command 24- Trinnov Dmon6
Old 09-22-2021, 11:30 AM
cool, thanks for posting!
can you monitor different input sources with the controls of the D-Command?
Old 09-23-2021, 06:59 AM
francois's Avatar
Yes ,I have 3 input sources at the moment and it works at it should from the control of the D-Command
Old 09-23-2021, 07:48 AM
Thanks!
Old 09-24-2021, 03:34 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Last time I looked into this the processing latency was the dealbreaker.
Will Russell
Electric Wilburland Studio
www.wilburland.com
12 core 3.06Ghz MacPro, OS 10.14.6, PT2021.6, HDX, D-Command
Retina 5k iMac OS 10.15.6, PT2021.6, BabyFacePro FS
Retina MacBook Pro OS 11.4, PT2021.6
Old 09-27-2021, 01:15 PM
francois's Avatar
No issues with latency ,no complaint from talent so far.
I still keep an extra digital pair of output( not Trinnov processed) into a Lavry D/A direct into the speakers in case such a problem arise.
Old 09-27-2021, 11:49 PM
Does the Trinnov not have a bypass function where you bypass both processing and induced latency?
Old 09-28-2021, 07:09 AM
francois's Avatar
yes
S6 and MTRX monitoring - Trinnov Dante Insert? acacia Avid S4/S6 8 08-22-2021 02:31 PM
Trinnov D-Mon 8 antonis Post - Surround - Video 4 03-01-2016 12:03 AM
Any difference besides color between D Command and D Command ES? diamondschwin Pro Tools TDM Systems (Mac) 10 03-12-2012 12:15 PM
Command Keyboard Focus mode ' E ' command bug ? vudoo Pro Tools TDM Systems (Win) 2 09-10-2009 05:49 AM
Total Loss of Command 8 Command/Modifiers John Pisciotta ProControl, Control|24, Command|8 1 05-13-2005 10:30 AM
