Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 05-12-2021, 11:26 PM
Bransenlane Bransenlane is offline
Default Count off adding more beats then set for
I am running pro tools 2019.6 on an iMac 10.13.6 with an apogee duet.
In every session. I set the count off for 2 bars for a total of 8 clicks before recording begins. Sometimes it will add additional clicks before recording which causes issues when tracking obviously. I noticed if the marker is places lets say to beats past the start of the bar it will add 2 extra clicks instead of the 8 I set it to.
What am I doing wrong here? I have count off selected with 2 bars, the metronome and conductor buttons are both activated.
Old 05-13-2021, 01:51 AM
BScout BScout is offline
Default Re: Count off adding more beats then set for
Is this a serious question? Assuming your English was "two beats before the start of the bar" -- then yes, of course, it will add 2 extra clicks. Why would a program second guess where YOU put a playhead? A count off is an addition to where you place the playhead.
It isn't a mind reader.
Pro Tools Ult 2021.6, HDX 3, MTRX/SPQ, HD OmniS1 x 2, FireHD x 2, Dock, iPad Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 05-14-2021, 11:28 PM
Yes this is a serious question I used to be able to put the play head anywhere in my project and the count off would always be 8 clicks. I knew exactly when to start playing. Now it changes some times it will be 9 clicks or 15 clicks. its never consistent. If this is normal then idk how i was able to use it for so long where it was alway only 8 clicks.
Old 09-23-2021, 08:13 PM
allanfelipe allanfelipe is offline
Hi, I have exactly this same problem. Does anyone have a clue what it could be?
Also related to https://duc.avid.com/showthread.php?t=364287, although it seems it wasn't solved there.
Since the person who answered the question here didn't understand it, let me try to explain it too. I want the recording to begin immediately after a 1 bar count off, which means I want to hear 4 clicks, but sometimes I hear 5 or 6 or the recording even begins after 3.5 beats. In my case I realize that when
Old 09-23-2021, 08:14 PM
the cursor is on top of the first beat of a bar, the count off works as expected. When it's on the second beat (like 3|2|000) there is an extra beat (so I hear 5 clicks). When it's on the third beat, there are 2 extra beats (clicks) and when it's on the fourth beat there are 3 extra beats (clicks).
Some settings: my conductor is on, the pre-roll / post-roll are disabled, the meter is set to 4/4 and dynamic transport is disabled.
What is going on?
Old 09-23-2021, 08:15 PM
Ps: Sorry to break the post in two, I'm receiving the following error message when I try to post. I'm not so sure, but it looks like a character limitation. If possible, an adm can paste the second msg inside the first.
"Access Denied
You don't have permission to access "http://duc.avid.com/newreply.php?" on this server.
Reference #18.373106c9.1632452593.5e3b9e46"
Old 09-23-2021, 08:33 PM
JFreak's Avatar
JFreak JFreak is online now
DUC has had these posting problems lately, no worries
Janne
Pro tools 10.3.2 adding erroneously recording countoff bars tj2toxic Pro Tools 10 1 08-09-2013 10:46 PM
How to add more bars before zero? jimbojimbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 09-08-2011 12:43 PM
help with bars and 7.4 hodge Tips & Tricks 10 03-20-2010 09:35 AM
Add bars Soundtrack2life Pro Tools TDM Systems (Mac) 2 12-18-2009 09:23 AM
OT: Bars on a sequencers vs. Bars for a writer DEVIZE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-01-2003 12:35 AM
