Using a Octo-Pre, Apollo and PT 12.5
I just upgraded from PT9 to 12.5, bought an Apollo Twin Duo everything was fine until I added a Focusrite Octo-Pre. Where I'm having a problem when I'm micing my Amps everything sounds great while recording the playback sound completely out of phase . I’ve spent hours on Focusrite, Universal Audio and Pro tools forums on Face book no one seems to have the answer. So is anyone in this forum using the combination as me? The hardware setup is pretty simple the setting on the OctoPre and Apollo I’m 99% sure of. The only inputs I can record on are MON/L/R.L (MON0) OR MON/L/R.R (MON0) I usually record on MIC?/LINE/HIZ/LINE.L (Mono) for some reason I’m not able to record on that input with the OctoPre I think that’s the problem. Any suggestions? BTW I’m new to this stuff.
Re: Using a Octo-Pre, Apollo and PT 12.5
If all the proper IO names are not showing up in the Setup>IO pages, click the default button on each page. I doubt anybody here has a chance of understanding what you mean by "Where I'm having a problem when I'm micing my Amps everything sounds great while recording the playback sound completely out of phase". What "amps/cabs" for what? With what microphones? Positioned where? Compared to what exactly that sounds better? You using Unison modelling? Post a sample on Soundcloud showing the difference. How are you determining it is "out of phase"? |
On the Apollo Console all 8 of the ADAT's are visible. I've also reset the Default setting on the I/O many times. I'm just saying sounds like it's out of Phase not sure if it is.
Out of phase with what? Did you move the mic between using the built in preamps and the OctoPre? You playing back multiple different mic channels at the same time (where phase will really show up). You can always stick a plugin with phase invert on the track and play (trim, channel strip etc.). Again nobody here likely has any hope of understanding what you think you are hearing. So post a sample. |
I figured it out , ADAT on the in's
I could of sworn I tried that, Your first post got me thinking or the two Rum and cokes. Thanks for the help.
It's so sad about Ray... da-da, da--da, da-da-duh.
"The most hateful man in Scotland." Lines from a beautiful song and a good movie.
Pro Tools 12.4 HDN, PCIe, Omni & Digi 192 ASUS Sabertooth, Intel i7 3820 3.6Ghz 32 GB 1600Mhz Corsair RAM SSD 500GB Samsung WIN 10 64bit |
FS:UAD-2 Satellite Thunderbolt OCTO - EU | SmartGear | Buy & Sell | 1 | 05-05-2016 04:48 AM |
FS: UAD 2 OCTO PCIe Custom with a lot of plugins | HolB | Buy & Sell | 2 | 12-07-2014 11:06 AM |
Octo preamps Question | jeam25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-12-2009 09:23 AM |
octo-ready pc quad yet? | unclemonkey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-16-2007 07:53 AM |
Focusrite Octo-Pres....Anyone using em???? | Loftman | Pro Tools TDM Systems (Mac) | 2 | 12-20-2002 08:33 AM |
