Having to Switch Playback Engine EVERY TIME I open a session
Hello.
I had recently gotten a replacement iLok. I’m not sure if this is related to the problem or not. I’m only mentioning this because that’s when this problem began occurring. Everything seems to be functioning fine, except when I open a new session that was using a playback engine other than built-in output, I get a message saying that it doesn’t support 44.1 kHz. Screen Shot 2015-11-14 at 7.35.33 PM.jpg I then switch the playback engine to built-in output and the session opens fine. I then switch the playback engine (with the session open) to my Avid MBox Mini, and the session re-opens with the correct playback engine and runs fine (even though the same thing pops up about the sample rate). My question is, is there any way I could fix this issue so that I can simply open the session with the proper playback engine and not have to switch and switch back every time I open a different session? Thanks. [Pro Tools 11.3.1] [Mac OSX 10.5.5] [Avid MBox Mini]
-Matt Heath | www.50HzSounds.net |
Re: Having to Switch Playback Engine EVERY TIME I open a session
I just upgraded to ElCapitain on iMac and can no longer see my AudioBox 1818vsl on th elist and ProTools will no longer import audio giving the following message:
Just upgraded to El Captain on iMac and have received the following message on my iMac: Cannot Import Audio Command because Assertion in”/Volumes/Development/151228/ProTools/NewFileLabs/Cfd/MacBuild/ ../MacOSCfd_ImportAudioDialogMacOS.mm”, line 559 Any help would be sincerely appreciated please |
Yep, that's a known bug with 11.3 and El Capitan. No way around it. You'll probably notice too, that after you get that error, your solo and record buttons no longer work. Only options are to upgrade to PT12, or find a way to downgrade back to Yosemite.
PC workstation: Windows 10 Pro i7 12700K RTX 2080ti 64GB DDR5 5200mhz RAM 2 Samsung 980 Pro 1TB SSDs Samsung 850 Pro 1TB SSD LG 34" Ultra-Widescreen monitor Pro Tools 12.4 A loaf of bread A stick of butter A lot of rye whiskey |
Having to Switch Playback Engine EVERY TIME I open a session | MattyJones | Pro Tools 11 | 0 | 11-11-2015 09:50 AM |
Playback Engine Issue (Won’t load session with chosen playback engine) | MattyJones | Pro Tools 11 | 0 | 11-02-2015 11:52 AM |
Default Playback Engine on session open | bgsoundman | Pro Tools 11 | 2 | 03-19-2014 08:25 PM |
audio engine error message upon trying to open a session | TWY | Windows | 0 | 08-28-2011 01:51 AM |
Playback engine every time... | GW | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-13-2003 11:01 AM |
