Old 05-23-2009, 03:20 AM
splicestudios splicestudios is offline
Default -18dBFS (Europe) / -20dBFS (USA) Reference Tones
I'm involved in a project that has deliverables to both UK and USA (co-production, hence the double deliverables): the UK master uses -18dBFS reference tone, peaks no more than 8dB above reference (i.e. -10dBFS), the US master uses -20dBFS reference tone and peaks at -10dBFS. So both peak at the same level. I've seen DCI specs before where the LM100 (yes that dreaded box) has different readings for PAL (UK) and NTSC (US), giving the PAL range as 2dB higher (-24 to -26, versus -26 to -28), which I assume mean that PAL is louder than NTSC by 2dB.
So am I right to assume that the UK specs allow for a narrower dynamic range (slightly more compressed sound), that would also average 2dB louder than its US counterpart? I've read DCI specs discussing RMS voice for their shows should be -32 to -20dbFS but overall RMS / VU should never pass -17dBFS.
I always think of British shows as having a more 'open' and dynamic sound, and US shows as having a far more in-your-face sound where everything is loud (although not necessarily through just applying heavy compression / limiting).
In making the 2 versions, it's not just a case of me dropping the overall level of the mixer (who is PAL and uses a -18dBFS reference) by 2 dB to compensate for the US master?
It wouldn't work the other way - a US show at -20dBFS ref with peaks at -10dBFS can't be bumped 2dB cos it would make for peaks of -8dBFS.
Or... have I got this entirely ass-backwards?
Even though I am in a PAL country, most of my broadcast clients go with US-style conventions of -20dBFS ref and -10dBFS peaks.
Regards
Kenn Delbridge, MPSE
SPLiCE Studios
Singapore
Old 05-23-2009, 03:49 AM
Branko's Avatar
Branko Branko is offline
Default Re: -18dBFS (Europe) / -20dBFS (USA) Reference Tones
This paper will answer most of your questions.
Here you'll find that you can retain your 10 dB headroom when printing for EBU-aligned countries. They specify 9dB (in some cases 8) peak over reference level, measured with quasi-peak meters, which would allow (due to differences in quasi-peak and true peak metering) for even higher peaks in your program. The question is: what instruments are your clients (broadcasters) using to measure peak levels?
Old 05-23-2009, 04:05 AM
The first mix that I am transferring to tape for this project I assume to have been mixed with limiting set at -10dBFS; nothing is surpassing this: I'm using a Dorrough 280D and during dialog / narration, it's showing -10dBFS peaks almost continuously: bump this 2dB and I'll get continuous peaks of -8dBFS, and being a documentary, it's voice heavy.
I know no-one seriously uses the meters on the front of a DigitBeta or HDCAM, but I similarly see the peaks stuck at -10dBFS when there's narration / dialog as it's going to tape for the US version. I assume before even going to a stand-alone meter that someone at the UK side will look at the PAL version bumped 2dB and see peaks for all narration / voice reading continuous -8dbFS peaks.
Old 05-23-2009, 01:58 PM
jahtao jahtao is offline
Sounds to me like only difference between the two deliverables' levels is the tone?!
Old 05-23-2009, 05:56 PM
infiniteloop infiniteloop is offline
If you put the Phasescope plugin in your master output and change it to "BBC", that PPM meter will give you a cast-iron OK for the UK master. As long as it doesn't peak over 6 on that meter, you're OK.
HTML code is On
converting from -20dBFS to -18dBFS and staying at -24LKFS PostGuys Post - Surround - Video 4 09-12-2013 03:31 AM
Creating Custom Keyboard Tones Based on Reference Sounds johnbarnesiii Pro Tools 10 2 07-12-2012 02:26 PM
0 VU / -18dBFS LEDD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 05-27-2004 07:58 AM
96I/O at -18dBFs??? is it possible? S-pole Pro Tools TDM Systems (Mac) 2 05-02-2003 05:32 AM
+4 dBm = -18dBFS or -20dBFS or -16 dBFS (ARGH!!) McMasters Pro Tools TDM Systems (Mac) 0 11-29-2002 10:02 AM
