can a Digi 002R clock to an Apogee DA16x via ADAT?
I own a Digi 002R and have borrowed an Apogee DA16x
The Digi 002R does not have a word clock in I have hooked the 002R ADAT out into the Apogee DA16x ADAT in at 48k The DA16x is set to internal clock The 002R refuses to set sync to the ADAT ... and keeps reverting to internal clock. Am I screwed? Can I not get the benefit of the Apogee clock? (The DA16x does not have an ADAT out, of course.) |
Re: can a Digi 002R clock to an Apogee DA16x via ADAT?
I synch to my 01v96 via ADAT so it is possible. Make sure your digital input is set to RCA=S/PDIF, Optical = ADAT, then set your clock source to ADAT.
I was just noticing the other day how the MBOX 2 Pro has Word clock connectors and the 002R doesn't.
Mark Reis Sound Designer |
The 002rack doesnt have wordclock in - ARG - so i can't use the DA16x with it. (unless I also had a Big Ben or similar) |
Firefox,
Shouldn't it be your Apogee DA16x ADAT out connected to your 002R ADAT in instead? harrio |
That's right. I am thinking A/D.
harrio |
You could sell your 002R and for the same money buy a MBOX2 PRO which has wordclock i/o and slightly better sounding A/D and D/A convertors than the 002R.
The only downside to the MBOX2 PRO is its not rackmountable and has no ADAT |
DIGI 003 + Apogee Ensemble + Apogee Big Ben = World Clock | marcioguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-11-2011 02:24 PM |
Can a Digi 888-16 clock be SLAVED to Apogee DA16X via BNC ? | schizo | Pro Tools TDM Systems (Mac) | 4 | 05-04-2007 12:33 PM |
Is anyone using one Digi 192 and one Apogee DA16x? | MixerGuy | Pro Tools TDM Systems (Mac) | 11 | 03-22-2007 03:45 AM |
Using Apogee AD-DA16X on Mix Plus | jpd52 | Pro Tools TDM Systems (Mac) | 2 | 01-16-2007 05:07 PM |
Setup issue regarding Digi 192 and Apogee DA16x | Redsandblu | Pro Tools TDM Systems (Mac) | 0 | 06-05-2005 05:08 AM |
