HD Project w/ SD Work Picture for the mix
I just did a project and the client failed to mention that the project was all in HD @ 24fps.
I mixed it fine but I don't have HD viewing capabilites other than the Computer Monitor. I thought that HD was 23.xxx fps. There is another project scheduled for a week from now. What do I need to be able to view this through my Canopus and NTSC monitor... and provide the edit house with a frame acurate mix? |
Re: HD Project w/ SD Work Picture for the mix
tell the editor that you are working in an SD environment. give them your specs. they'll provide you with a cross converted file.
do you work, mix, create a file and send it back. i did my first 5 HD projects looking at Standard Def video. also, i provide my assistant with NTSC QT's and our work travels back and forth between my small rooms just fine.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
but what about the frame rate conversion from 24 to 29.97?
Philip Perkins |
The sent over a SD conversion and it worked great. I've informed them and now we both know.
Thanks for the help guys! |
Pro Tools 10 will not work with vocalign project LE | Drywsef | macOS | 9 | 02-12-2013 07:08 AM |
picture UN-locked, reconforming work | KingTor | Post - Surround - Video | 2 | 02-15-2010 08:55 PM |
How can I work on a project away from my hardware? | oldhousedave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-31-2005 03:45 PM |
Work Flow for new project | Lanois WannaB | Post - Surround - Video | 8 | 07-22-2004 11:11 AM |
Does Project card work on a G4 | smaug | General Discussion | 0 | 02-28-2000 09:08 AM |
