Re: Pro Tools 12 Midi Track Volume Not Controlling Plugins
Mac Pro 2x2.8 ghz Intel Zeon, 20 gig ram, Yosemite 10.10.5, Pro Tools 10,11,12.7.1, Logic Pro X 10.2, UA Apollo 16 quad, UA Octo Pcies, Dangerous Music 2 Bus, Antelope Audio Satori, Lynx Studio Hilo, Neve 542, Neve 511, API 505 DI, Bettermaker CV502. Avid Artist Mix, Avid Artist Control, Softube Console 1 mk11. |
+1
I use a significant number of hardware modules, not sending cc07 is extremely annoying... |
I was wondering why I was having this problem with PT12 and VePro. I rarely use PT for midi, since it still struggles with VI's in comparison to other DAW's I have.
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII |
+1 No volume midi here. CC7, as it should be. I thought there was something wrong with vienna pro. Thank you for a future fix, Avid.
Is the problem solved with 12.3 ??
Wondering if switching to Logic wouldn't be the best solution.. |
Logic for programming always! Pro Tools for audio/mixing always!
Hello, it's my first post here
I've upgraded my PTHD 10 to PTHD12 a few days ago and really like the new features on PTHD 12, but unfortunately the PTHD 12 is totally unusable for me because of the MIDI bug in discussion. I mix on an SSL AWS console together with an SSL Sigma, the Sigma is controlled by PT using midi faders which are controlled by the AWS console faders, so the Sigma is an extension of the AWS in my rig.. It has worked perfectly in PTHD 10, but after installing PTHD 12 it doesn't work anymore, I've spent hours trying to realize if something is wrong with my MIDI setup but everything seems to be fine. I can't change the Sigma volumes at all while PTHD 12 isn't playing. And while playing the volume change only take place when I take my finger off the AWS fader which make my system unusable for dynamic mixing and I can only use it on unity gain as a summing box but that's not my workflow. I'd like to know if these are MIDI bugs or Avid has decided to change the MIDI workflow ? If it's a bug does Avid has an estimation when it will be fixed ? If it's not a bug and Avid has decided to change PT midi protocol I think it would be fair to let the users know about it before they upgrade because for some users like me MIDI volume behavior is an essential thing of their mixing rig.. It would help to know when if at all it will be solved because I've just spent 599$ on upgrading my system and I'd like to degrade back to PTHD 10 and get money refund because the present is PTHD 10 because of projects backward compatibility, and the future will have to be something else |
Re: Serious MIDI bug in PTHD 12 ??
I would pester Avid support about this...since that is what you payed for in your upgrade/support plan
www.olipoulsen.com iMac27 i9 3.6 (late 2019) / 64 GB Ram / OS 10.15.7 Apollo 8 / PT Ultimate 2020.9.1 |
Not sure if this is any help, but be aware that PT resets all the MIDI setups and preferences to their defaults when you install a new version. So if you had to alter some preferences or peripherals to set up proper control of the Sigma, you will have to do these things again.
Hi
……And while playing the MIDI volume change only take place when I take my finger off the AWS fader which make my system unusable for dynamic mixing and I can only use it on unity gain as a passive summing box but that doesn't fit my workflow. ………… This also true for any other MIDI instrument (outboard and VI) This MIDI bug is since PT12 and I hoped for 12.3 But AVID was busy implementing new features (which I love) but I rather prefer basic relyability and functionality. MIDI track faders became useless …… absolutely ridiculous (I already pointed out in various other threads) AVID should fix this very basic MIDI bug immediately !! sincerely Walter |
Instrument Track Region: Adjusting Volume? | johnbarnesiii | Pro Tools 10 | 1 | 06-21-2013 03:26 PM |
Midi Fader Volume - Instrument & Midi Track | blizzard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-11-2010 09:35 AM |
Pre-fader metering doesn't affect auxes? | jstaczek | Pro Tools TDM Systems (Mac) | 5 | 09-14-2007 03:37 PM |
Adjusting fader/rec/sel/sol In midi track problem | junkgem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-23-2006 06:42 PM |
Crash when adjusting Instrument track MIDI volume | Helge Krabye | Pro Tools TDM Systems (Mac) | 0 | 01-28-2006 02:33 PM |
