Old 05-14-2018, 09:05 AM
MIXER500 MIXER500 is offline
Default Clip Gain Display in Regions in 2018.4?
Currently working on a project that requires a lot of level management via clip gain. I've noticed that the clip gain level display in the regions sometimes disappears. It seems like it's related to editing the regions. For example, I make an edit in a region and adjust the clip gain of the now latter region. If I decide I don't want to keep that edit there and I heal the separation, the edit will disappear and bring the clip gain display with it. I can see the fader in the region but the level display is gone. As I'm trying to balance room tone with these regions, losing the gain display is extremely disruptive. Any ideas?
On Ultimate 2018.4/Mac Pro (Late 2013)/2.7 GHz 12-core Xeon E5/64 GB RAM
Running MacOS Sierra (10.12).
Old 05-14-2018, 09:21 AM
home_studio home_studio is offline
Default Re: Clip Gain Display in Regions in 2018.4?
If you 'heal separation' two clips with different clip gain it can't tell you the clip gain for the healed clip. It makes sense to me.
Any ides? Don't heal clips with different clip gain.
2023.12 Ultimate / Mac Pro (Late 2013) / 6 core 3.5GHz / 64Gb / OSX 12.7.2 / MTRX Studio / 2xArtist Mix / PT|Control / Aja T-Tap
Old 05-14-2018, 09:52 AM
How fantastic that it makes sense to you. I have a great idea: maybe if you have nothing constructive to add, don't post?
Old 05-14-2018, 10:51 AM
Wizzoboy's Avatar
Wizzoboy Wizzoboy is offline
Unable to check at the moment, but have you looked at the "volume" automation lane to see if there is a step change where your edit used to be? Just a thought.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring.
Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n
Old 05-14-2018, 12:00 PM
BScout BScout is offline
It's what Wizzoboy wrote.
If you adjust clip gain on one section of an edit and then heal, the fader loses any numerical meaning because now the clip gain line shows the clip change. Show the clip gain line and you'll see a step for the change.
You can also tell if this has happened (or if you put breakpoints on the clipgain line) because the fader will now show a delta change (triangle) when adjusting the clip fader since it is doing a relative change for the whole clip gain line.
Only way to get the numerical value back is to reset the clip gain (which wipes all clip gain line changes) and then readjust.
It's operating as it is intended.
Old 05-15-2018, 01:54 AM
I wasn't meaning to be rude.
It makes sense since the clip gain cannot show 2 values of one clip.
Telling you that this is how it works in pro tools (whether you like it or not) and why it behaves like that, is constructive enough.
Old 05-15-2018, 08:44 PM
wwittman wwittman is offline
but he was
clearly
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
Old 09-19-2021, 06:04 AM
Hellena Hellena is offline
Your answer helped me, thank you very much. For the record, I didn't think you were rude at all.
Old 09-19-2021, 01:56 PM
You can convert Clip Gain to automation, then consolidate the audio Doing this will remove the Clip Gain changes from the Clips(so healing will restore the audio back to what it originally was). You can also go the other way and convert volume automation to Clip Gain. I also would simply not heal the separation(unless you have some good reason why you need to)
Old 09-19-2021, 04:31 PM
Sardi Sardi is online now
Just an FYI - that’s a PT Ultimate feature. You can’t do that in the standard version.
I know the OP mentions PT Ultimate, but seeing this a 2yo thread that’s been bumped, might be good to point that out for anyone else that sees it.
clip gain 12.8.3/2018.1 Norad155 Post - Surround - Video 9 09-10-2018 06:42 PM
Adjusting Clip Gain On More Than One Clip Blank Frank macOS 17 05-15-2015 06:34 PM
AudioSuite Gain/Normalize also on Clip Gain A-n-d-i macOS 0 03-13-2014 12:46 PM
Export Clip With Clip Gain BobbyDazzler Pro Tools 10 0 03-03-2013 03:06 PM
Clip gain on clip groups: bug or feature? idris Post - Surround - Video 6 01-02-2013 10:48 PM
