Re: Minimize Additional Latency noise
No I don't think so - I would however make sure the software is up to date and qual'd for PT11
I never used that button till once and did some vocals and in the mix I heard pops and clicks that were on the actual audio track - never check it since I don't know at this point - I assumed the easiest fix - doesn't sound like its easy Why not leave it at 64? Or 128 I don't think most systems sound fine at that sample rate
I was just hoping I could get low latency at higher buffer settings like I can in Logic Pro with their "low latency button". I will take your advice and use the 64 and 128 settings when recording. Thanks for your help! J |
Yeah that's the best I've got - sorry hopefully someone can chime in and point u in the right direction
I appreciate your help! Hopefully I will find a solution soon. I am thinking that not too many people have actually checked this "Minimize Additional Latancy" box.
I realize this is an ancient thread but just in case anyone else stumbles across it like I did, this is what the manual has to say:
The Host Engine options in the Playback Engine determine error reporting during playback and recording. This is especially useful when working with instrument plug-ins. On Pro Tools|HD systems, there is a single Host Engine option. On host-based Pro Tools systems, there are two Host Engine options. • Enable error suppression only if you are experiencing frequent errors that are interrupting your creative workflow. When error suppression is enabled, you can experience a degradation of audio quality. However, this may be acceptable in order to avoid interrupting playback and recording when working with instrument plug-ins. • Disable error suppression when you need to ensure the highest possible audio quality, such as for a final mix. |
PT 9 - "Minimize additional I/O latency" PROBLEM | elmodagansta | Windows | 2 | 04-27-2013 06:11 AM |
Minimize Additional I/O latency | william.bond55 | Pro Tools 10 | 0 | 03-16-2012 08:44 AM |
Whats the best way to minimize midi latency | weezerboy | MIDI | 3 | 08-04-2008 09:44 AM |
How to minimize latency | ram1500 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-02-2007 03:13 PM |
how best to minimize latency? | vyatka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-11-2000 07:48 PM |
