getting sampletank to play using the pencil tool?
Can anyone help my friend and I?
We are trying to learn to use the pencil tool to draw the midi info using the piano key view, and then play it back with sampletank. I don't use midi, much but my friend wanted to know if this was possible. I've reviewed the manual and can see some info 369 and 377 buts its still confusing and doesn't address sampletank in particular. Anyone have any ideas or technique or help to share?
Dan Atkins The Electric Trombone Studio |
Re: getting sampletank to play using the pencil tool?
just write the events you want, in the midi track you've already outed to the smpltnk in the midi channel you choosed.
so what |
yes... it will work. Basically, the steps are these:
1) Create new MIDI track 2) create new AUX track 3) load SampleTank as a plug-in on your AUX track 4) select (double-click) a SampleTank instrument 5) on your MIDI track, under output section, select the SampleTank instrument from step #4 6) record-enable MIDI track and make sure AUX track's fader is pulled up. 7) pencil in your notes on the MIDI track that should be it. MIght be more info on the thread HERE. Post back if you have problems. |
Is is possible to change the shortcuts for the Pencil Tool, Grabber Tool, ETC? | jgagne1 | macOS | 2 | 09-24-2013 07:46 AM |
Pencil tool with Smart Tool | P_J | Pro Tools 10 | 0 | 04-24-2013 01:13 AM |
Pencil tool turns into mouse pointer tool when drawing | arvid.lind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-11-2010 12:36 AM |
Free Hand Pencil Tool Becomes Line Pencil Tool | Vogger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-27-2009 10:23 PM |
Smart Tool / Pencil Tool in Midi Editor | AndyJCP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 04-26-2009 08:08 PM |
