Old 12-06-2012, 09:00 PM
rockguitarist1255 rockguitarist1255 is offline
Default What are the difference between using a "mono" vs "mono/stereo" plug in on mono track
Okay so I know if I have a mono track, I can obviously use a mono plug in on that same track.
When I insert the same plug in to that mono track in "mono/stereo" mode, then that mono track changes to 100 left and 100 right.
So basically, what does that mean in terms of sound difference between the two? I'm just curious.
Old 12-06-2012, 09:13 PM
nst7 nst7 is offline
Default Re: What are the difference between using a "mono" vs "mono/stereo" plug in on mono t
That will mainly apply to effects like delays, reverbs, etc. It's the same thing as using an aux send on a mono track to a stereo aux track with a stereo plugin. It just allows you to use it as an insert instead.
For example, you can have your mono lead guitar going into a mono delay, or into a stereo delay, where the delays are wider and spread apart. You could achieve that with either method I just mentioned.
Old 12-06-2012, 09:17 PM
Oh okay that makes sense. I didn't know you could do the same thing with a mono/stereo plug in. I thought you just had to send mono tracks to a stereo aux to get the effect. Thanks!
Old 12-06-2012, 09:58 PM
soybalm soybalm is offline
It allows for stereo fx like reverb, stereo delay, chorus, etc. A stereo track always has the 2 pan pots for flexibility. You can overcame the volume shifts by adjusting the pan laws in the session window in the windows tab.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 12-07-2012, 08:07 AM
elicious elicious is offline
be aware also,
you've just doubled your power ratio;
i.o.w., a 3 db increase...
e
ihatetyping
Consolidate vs Duplicate - "Stereo" vs. Dual Mono Behaviour rnd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-05-2013 01:03 AM
Can you have "center" as default view with multi mono plug in? dgoodi22 macOS 4 02-08-2013 12:41 PM
Mono, but no "Beatle Stereo" Moses Presley Tips & Tricks 18 09-22-2003 02:51 PM
HOW can you import a "stereo" WAV. file into PT as a "mono" file? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-21-2002 09:14 PM
What do i import a "dual mono" audio file as??? mono or split stereo? peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-17-2002 04:02 AM
