Old 10-16-2011, 09:56 AM
msemesky msemesky is offline
Default Digi 002 playback issue
Hey guys,
I'm having a playback issue using my Digi 002 through Cubase 5. The playback is consistently jumpy and stuttered. When changing the buffer size from 256 to 2048, the issue is less severe but not not solved. I've tried installing basically every driver known to man and this is the one that I'm currently using: http://avid.custkb.com/avid/app/self...p?DocId=379411. After exporting a session, the audio sounds normal. It's only during playback in the session that the audio sounds this way. Any help with this issue would be greatly appreciated!
Thanks!
Old 10-20-2011, 01:19 AM
perfectdrug6 perfectdrug6 is offline
Default Re: Digi 002 playback issue
Hey man, I think I'm having the same problem, my playback even on a blank session is choppy, like can't hold a constant tempo. I've tried so many things I'm beginning to think the digi itself is broken. Anyway, if you figure it out please let me know, and I'll do the same.
Digi 002 Power Harness Issue or Firewire Chip Issue? Nish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 35 05-07-2010 01:25 PM
Quicktime Pro Playback issue w Digi Hardware Dennis Scott Pro Tools TDM Systems (Mac) 1 11-20-2009 10:56 AM
Quicktime Pro Playback issue w Digi Hardware Dennis Scott Post - Surround - Video 0 11-20-2009 07:34 AM
QuickTime Pro Playback issue w Digi Hardware Dennis Scott Pro Tools TDM Systems (Mac) 7 06-23-2009 09:40 AM
DIGI 002rack PT LE 7.0 MacG4 800MHz playback issue PolishWarBride 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-18-2006 07:36 PM
