Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 06-15-2010, 10:07 PM
Mad Genius Audio Mad Genius Audio is offline
Default Recorded audio shifts forward
Hey all,
I may just be freaking out, but lately when I've been tracking myself to Pro Tools, I make sure to play very tight to the rhythm section (EZDrummer, so it's locked to grid), yet when I stop to play back, all my audio seems to play in front of the beat. I've determined it to be about 30ms, so nudging all of my regions later by 30ms seems to fix this issue, but I'm wondering if there may be some preference that may be checked or unchecked that should not or should be. I run PT M-Powered 8.0.3 on Mac 10.5.8 using an M-Audio 1814 interface. Any thoughts are appreciated. Thanks!
MGA
Old 06-15-2010, 10:37 PM
clausiii's Avatar
clausiii clausiii is offline
Default Re: Recorded audio shifts forward
you can set a midi playback offset for your session. Don´t know where right now, not sitting in front of PT...
search in the reference guide for midi offset...
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 06-16-2010, 07:18 PM
Good call, I'll go give that a shot, I'll let you know the results.
MGA
Xform causing random pase shifts in audio (drum tracks) in PT8 bryanatt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-21-2011 01:51 PM
timeline shifts and playlists pt8 brianjanthony Pro Tools TDM Systems (Mac) 2 10-22-2010 02:06 PM
Audio moved forward after recording stopped... O.G. Killa Pro Tools TDM Systems (Mac) 44 01-13-2006 08:48 AM
Problem that region shifts!! K.I. Pro Tools TDM Systems (Mac) 2 04-28-2005 09:13 PM
Smooth audio in fast forward mampam Pro Tools TDM Systems (Mac) 0 12-13-2004 09:26 AM
