Noise/Glitch Pro Tools Academic 7.3.1cs1
Since I updated my Pro Tools M-powered Academic 7.1 to the 7.3 version, I hear noise/glitch, a bit like an annoying click. I tried updating to 7.3.1... same thing. 7.3.1 cs1 also.
HELP plz. |
Re: Noise/Glitch Pro Tools Academic 7.3.1cs1
On session that were not noisy on pro tools 7.1. Someone plz.
if you want help, please post SANDRA information:
-------------------------------------------------------------------------- - SiSoftware's Sandra Lite application can be used to post your full system profile: www.sisoftware.net Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. --------------------------------------------------------------------------
http://www.myspace.com/blaqmusicgroup |
check your buffer size, defrag your HD
Do you have an external hard drive set up? It could be you've got it set up incorrectly. I had those annoying clicks that seem to be in time, and that was my problem..
"check your buffer size, defrag your HD"
I did. I didn't work. Do you have an external hard drive set up? It could be you've got it set up incorrectly. I had those annoying clicks that seem to be in time, and that was my problem.. Yes I have. But the pro tools session on my internal hard drive do the same things. Computer: Operating System Microsoft Windows XP Home Edition OS Service Pack Service Pack 2 Internet Explorer 7.0.5730.11 Motherboard: CPU Type Unknown, 2800 MHz (3.5 x 800) Motherboard Name Dell Inc. Dell DM051 Motherboard Chipset Unknown System Memory 1024 MB BIOS Type Phoenix (03/31/06) Display: Video Adapter RADEON X600 Series Secondary (256 MB) Video Adapter RADEON X600 Series (256 MB) Monitor Écran Plug-and-Play [NoDB] (GC81165Q03WM) Multimedia: Audio Adapter Lecture sur modem n° 0 Audio Adapter M-Audio MobilePre Audio Adapter SigmaTel Audio Storage: Disk Drive Maxtor 6 L250R0 USB Device Disk Drive ST3808110AS Optical Drive HL-DT-ST DVD+-RW GWA4164B Optical Drive ZG5234F FGL914F SCSI CdRom Device Optical Drive ZG5234F FGL914F SCSI CdRom Device Partitions: C: (NTFS) 73155 MB (43430 MB free) H: (FAT32) 238414 MB (36742 MB free) Input: Keyboard Périphérique clavier PIH Mouse Souris HID Network Adapter Intel(R) PRO/100 VE Network Connection Modem Conexant D850 56K V.9x DFVc Modem Peripherals: Printer Fax Printer Microsoft Office Document Image Writer USB Device Concentrateur USB générique USB Device M-Audio MobilePre USB USB Device Périphérique de stockage de masse USB USB Device Périphérique d'interface utilisateur USB USB Device Périphérique d'interface utilisateur USB USB Device Périphérique d'interface utilisateur USB USB Device Périphérique USB composite USB Device Périphérique USB composite USB Device USB iLok Driver --------[ DMI ]--------------------------------------------------------------------------------------------------------- [ BIOS ] BIOS Properties: Vendor Dell Inc. Version A05 Release Date 03/31/2006 Size 512 KB Boot Devices Floppy Disk, Hard Disk, CD-ROM, LS-120 Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD, BBS Supported Standards DMI, APM, ACPI, PnP Expansion Capabilities PCI, USB [ System ] System Properties: Manufacturer Dell Inc. Product Dell DM051 [ Motherboard ] Motherboard Properties: Manufacturer Dell Inc. Product 0HJ054 [ Chassis ] Chassis Properties: Manufacturer Dell Inc. Chassis Type Mini Tower [ Processors / Processor #1 ] Processor Properties: Manufacturer Intel External Clock 800 MHz Maximum Clock 4000 MHz Current Clock 2800 MHz Type Central Processor Voltage 1.7 V Status Enabled Upgrade ZIF Socket Designation Microprocessor |
I believe your major issue is hard drive related. Also, as a note, Digi does not recommend or support recording to your system drive. This is a well known fact. I grabbed this from the Digi Support pages Quote:
I wear the pants. (My wife picks them out) |
I did a format. I created partition for windows and one for audio. My problem is solve. thx
what you are doing / have done is UNSUPPORTED.
you should consider buying an additional IDE/SATA/SATA2 hard drive (one that is 7200 rpm). they are only $35 on http://www.pricewatch.com from what you stated, you are using two partitions on the same hard drive - doing this is NOT supported. you need a separate hard drive to record / store your audio. good luck with that.
drumagog making odd "digital" noise in Record mode?PTsetting?glitch? | twig | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-26-2010 08:12 AM |
Pro Tools 8.0.1cs1 / FWX | Mike K | VENUE Live Sound Systems | 4 | 12-08-2009 08:27 AM |
M-Powered Academic 7.4 / M-Audio MobilePre USB Academic Error Message | JustparaDOX | Pro Tools M-Powered (Win) | 1 | 10-31-2008 10:09 AM |
Pro Tools 7.3.1cs1 don't do it | sctstudios | Pro Tools TDM Systems (Mac) | 9 | 02-22-2007 11:19 AM |
glitch noise when t-racks is instansiated | elheehaw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-18-2003 06:24 PM |
