Old 05-06-2021, 03:38 AM
Benoit Erard Benoit Erard is offline
Default Shortcut Problem with with switching Mix/Edit Page
Hi Everyone,
I m new on windows 10 and i have two problems.
First, the shortcut to toggle between windows (ctrl =) doesn t work.
All the other short cut are alright but not this one.
Second, i can t scroll left right with the pad on PT 12.
It does work on all the others app.
Can somebody help me please ?
I have a mix session starting in 1 hour huhu
Cheers
Old 05-06-2021, 07:33 AM
Default Re: Shortcut Problem with with switching Mix/Edit Page
Not a clue as it works fine here. Is there some keyboard utility being used to re-program any keys?
Not sure what "the pad" is. If you hold SHIFT, the vertical scrolling should switch to horizontal scrolling. If you are trying work PT on a laptop touchpad, I highly recommend adding a mouse or trackball. I'll do some recording with a track pad(and lots of moaning), but when it comes to editing, a touchpad leaves a lot to be desired
Old 05-06-2021, 12:33 PM
Thanks for the answer.
Just so you know, it was because it doesn t work with the swiss QWERTZ keyboard settings. i changed it to UK and now it s fine.
cheers
Strange Folder Shortcut problem in Edit Window grameswan Pro Tools 2020 2 11-08-2023 07:15 PM
Strange Folder Shortcut problem in Edit Window joeshepard Pro Tools 2020 0 06-04-2020 01:30 AM
Feat. Req: Stay on same page when switching track Frank Kruse Artist Series 12 01-17-2012 12:13 PM
MIDI edit page.... Edit Window Scrolling ... Page Norm Mix MIDI 1 07-06-2009 07:31 PM
PT8 switching between mixer/edit one-key-shortcut erans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-30-2009 03:14 PM
