Old 12-28-2008, 11:18 AM
StachO StachO is offline
Default Command8 rotary resolution?
If I'm using the EQ or other plug-ins of my M-Powered Software controlled by the Command8 there is a problem:
I use the rotary knobs to control the eq, but the resolution of the knobs is very low. If I turn right the knob then the gain steps from 0.7db to 1.3db. Every step of this knob has got a resolution of 0.6 or 0.7db.
If I flip them to the faders the resolution is 0.1db.
Is there an error or can it be adjusted in the Command8? I use the firmware 02.00.00 and Bootloader 1.0.
Old 12-29-2008, 04:44 AM
SKI's Avatar
SKI SKI is offline
Default Re: Command8 rotary resolution?
You can put the encoders in FINE mode for more precise adjustments.
URBAN MUSIC-
(Hip Hop and R&B)
Old 12-29-2008, 05:22 AM
Ok, but how do I do that?
In ProTools or in the command8?
Or is it decribed in the manual?
Old 12-29-2008, 05:37 AM
clusterer clusterer is offline
already tried:
command + turn rotary knob
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 12-29-2008, 06:55 AM
Thank you. This is much convenient. Or can it be locked?
Old 12-29-2008, 08:38 AM
so for what i know; you can´t...
Old 12-30-2008, 03:50 AM
pezking pezking is offline
You could use a bit of tape on your command button
Nah on a serious note, I don't think you can lock it.
Old 12-30-2008, 11:02 AM
Thanks for your advices.
Yesterday I bought a Digi003. I bought them in the US. I think it may last up to two weeks if item will be arrived.
Now the command8 is for sale.
Old 01-01-2009, 07:40 PM
SKI's Avatar
SKI SKI is offline
Not sure how that improves what you originally posted about but you will pick up some added functions with the 003.
URBAN MUSIC-
(Hip Hop and R&B)
Old 01-05-2009, 01:49 AM
The problem has not solved completely, because it is much convenient for me to use the control button and the rotary at the same time. I have to use both hands on the command8.
If you use an analogue mixing desk you can use one hand and you've got a higher resolution.
Ok, the command8 can flip the rotaries to the faders. This method is unusual, but it works.
[offtopic]
I don't bought the 003 to solve my problem. I bought them, because it was very cheap in comparision to the price in Germany. It gives me more flexibility in mobile recording.
[/offtopic]
Rotary knobs on my c/24 are malfunctioning panni ICON & C|24 0 05-24-2013 09:50 AM
No Rotary (Leslie) Effect dvjduck 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-30-2012 05:04 PM
Rotary effect MLE Eleven Rack 1 07-25-2012 09:27 PM
Rotary encoder resolution mixboy bob ICON & C|24 2 11-18-2008 04:43 PM
Rotary Sensitivity Setting colinweeks ICON & C|24 1 11-09-2007 08:55 AM
