No sound on audio track
Hey all,
I'm not sure if this is a known glitch - I've searched and couldn't find anything. I have an ongoing issue with a specific audio track not playing. The meters show audio is playing but there is no sound. This manifests itself in bounces as well. I've checked mutes, automation, routing etc. Sometimes, moving to a different timeline fixes it. Sometimes, routing the track to a different bus, then routing back works. Sometimes freezing the track works. Sometimes, duplicating the track works. I've tried deactiving the track and plug-ins. These fixes are very temporary (pressing play once) and then the problems persists. I'm on Monterey, M1 Pro, Pro Tools Studio 2022.10. Thanks in advance. |
Re: No sound on audio track
Do you have any plugins running in trial mode anywhere in the path of the routed audio?
There is very little to go off of in your explanation to diagnose the issue. |
Did you check monitor paths in I/O? Did you try resetting I/O to default? Screenshot of the offending track mix window?
No plugins running in trial mode.
I checked output paths and nothing seemed off, but I didn't check monitor paths. I'll try resetting I/O default. I'm not at my workstation right now but can upload a screenshot in a bit. Thanks for the suggestions.
I took off all plugins but the problem still occured.
I then set output and bus to default settings. I'm not sure if it's related, but the audio plays fine during playback now. However, it still mutes itself during off-line bounces. Real time bounce works fine. I also have issues with VST instruments not playing. In this case, duplicating the track or making it inactive, then active again works. Could there be a bigger issue with my system. At first, I just thought it was because PT wasn't native to Apple Silicon yet. Thanks! |
Audio track shows on session, but no sound from it? | rockguitarist1255 | Pro Tools 10 | 5 | 12-05-2022 04:23 PM |
Audio Track lags or doesn't sound at all! Please Help! | Edarel-Triparte | Windows | 4 | 10-01-2017 09:56 AM |
M-audio Fast track pro sound problems | Sonnebeats | FireWire & USB Audio Interfaces (Win) | 1 | 01-31-2017 11:07 AM |
Sound problem with M-Audio Fast Track w/ video | Freddy's Bar | Pro Tools M-Powered (Win) | 1 | 12-04-2010 01:51 PM |
help - no sound when playing back audio track! | newtoPT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-29-2006 01:33 PM |
