I've just setup a PC running HD1 on Win7 x64. It's built on the ASUS P755PD-LE and i7-870. The Command|8 doesn't connect with Pro Tools, but moving faders on the C8 and other knobs respons on PT but not the other way around. And of course the usual "cannot connect" window shows up telling to recycle the C8 or update periperals, which doesn't work. Here's how I installed the system 1) Clean Win7 x64 install updated through Windows update 2) Installed PT 8.0.0.3 3) Updated to PT 8.1 4) Updated to PT 8.1cs2 5) Turned on the Command|8, and the drivers were installed and Command|8 shows up under audio devices in device manager with a driver from 2007 from Focusrite. 6) Started PT without problems and runs fine, but when updating peripherals to Command|8 with midi send and return set to Command|8 it still shows not connected. PT resonds fader changes I do on C8, but not the other way around. I've tried all the available USB slots and have a good working USB cable. Can anyone help me? |
Right click on PTHD icon on desktop and select "run as administrator"...
HTH !
-C' ya' Rick MacPro 7,1; 16 core OSX 12.5.1 PT 2022.12; Eucon 2022.12 Dock/S1/2x iPad |
Thank you! That worked!! I can't belive I forgot to check the "always run as administrator".
Thanks again :) |
Command|8 trouble with Win7 x64 & PTLE 8.0.3 | ynor | ProControl, Control|24, Command|8 | 5 | 09-04-2011 02:02 PM |
instaling in win7 problem | raga2000 | Pro Tools TDM Systems (Win) | 0 | 01-10-2011 04:02 AM |
Command 8 under Win7 32b with PTLE8.0.4cs2 | francois.fab | ProControl, Control|24, Command|8 | 2 | 12-05-2010 01:37 PM |
BIG UNCOMMON 003 factory and win7 Problem! HELP! | tounez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-30-2010 04:21 PM |
MBOX2 PT8 DAE 1115 problem ON WIN7 and XP | Mokki | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 12-28-2009 11:26 AM |
