I have a Dell 1525 Vista Ultimate Laptop with 4 gigs of ram. I am having trouble getting the program to even start. During the install I get an error when the installer starts " Ms visual basic++C 2005". The error message is "Microsoft Registered Server has stopped working". I will press the 'closed' button and the rest of the install will happen.
After reboot, the program, on startup, crashes immediately. I have set all the settings in the vista support recommendations, but the right-click 'start as administrator' gives me an error also. Any suggestions is appreciated. Computer Model : Dell Inspiron 1525 Processor Model : Intel(R) Core(TM)2 Duo CPU T7250 @ 2.00GHz Speed : 2.2GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing Computer Platform Compliance : Intel Centrino Mobile Technology Mainboard : Dell 0WP007 BIOS : Dell A17 10/27/2009 Bus(es) : ISA X-Bus PCI PCIe IMB PCMCIA USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.5GB DDR2 SO-DIMM Chipset Model : Dell Mobile PM965/GM965/GL960 Express Processor to DRAM Controller Front Side Bus Speed : 4x 200MHz (800MHz) Total Memory : 4GB DDR2 SO-DIMM Shared Memory : 8MB Memory Bus Speed : 2x 333MHz (666MHz) Memory Module(s) Memory Module : Samsung M4 70T5663CZ3-CE6 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Memory Module : Samsung M4 70T5663CZ3-CE6 2GB DDR2 SO-DIMM PC2-5300U DDR2-666 (5-5-5-15 3-20-5-3) Video System Video Adapter : Mobile Intel(R) 965 Express Chipset Family (8 SP, Integrated Graphics) Graphics Processor Storage Devices TOSHIBA MK2546GSX (250GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) : 233GB (C:) (D:) TSSTcorp DVD+/-RW TS-L632H (ATA33, DVD+-RW, CD-RW, 2MB Cache) : 4GB (E:) Logical Storage Devices RECOVERY (D:) : 10GB (NTFS) @ TOSHIBA MK2546GSX (250GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) OS (C:) : 162GB (NTFS) @ TOSHIBA MK2546GSX (250GB, SATA300, 2.5", 5400rpm, NCQ, 8MB Cache) Pro Tools LE (E:) : 4GB (CDFS) @ TSSTcorp DVD+/-RW TS-L632H (ATA33, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell ICH8M-E (ICH8) LPC Interface Controller LPC Legacy Controller 1 : T0 FC-11h Audio Device : Dell 82801H (ICH8) HD Audio Controller Audio Codec : Conexant 2C06h Audio Codec : Silicon Image (CMD Technology) 1392h Audio Codec : Sigmatel 7616h Serial Port(s) : 2 Disk Controller : Dell 82801H (ICH8) Ultra ATA Storage Controllers Disk Controller : Dell Mobile SATA AHCI Controller USB Controller 1 : Dell 82801H (ICH8) USB UHCI #4 USB Controller 2 : Dell 82801H (ICH8) USB UHCI #5 USB Controller 3 : Dell 82801H (ICH8) USB2 EHCI #2 USB Controller 4 : Dell 82801H (ICH8) USB UHCI #1 USB Controller 5 : Dell 82801H (ICH8) USB UHCI #2 USB Controller 6 : Dell 82801H (ICH8) USB UHCI #3 USB Controller 7 : Dell 82801H (ICH8) USB2 EHCI #1 FireWire/1394 Controller 1 : Dell R5C832 IEEE-1394 Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Marvell Yukon 88E8040 PCI-E Fast Ethernet Controller Network Adapter : TAP-Win32 Adapter V8 (coLinux) (Ethernet, 100Mbps) Network Adapter : Bluetooth Device (Personal Area Network) #2 Wireless Adapter 1 : Dell Wireless 1505 Draft 802.11n WLAN Mini-Card (802.11g (ERP), WEP n-bit, 54Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows Vista Ultimate 6.00.6002 (Service Pack 2) Platform Compliance : x86 Windows Experience Index Current System : 3.5 |
Thank you for checking this post.
I have a mini PT hardware. I ran the DPC latency checker program and it advised it was fast enough. I know that does not mean everything.
I will go back to IE7 if that will help. I don't need anything cpu intense for the mini as I would be just using it for mobile simple things. I have an older MTD Pro setup on a Mac desktop. I hope to just get the program to run....thanks |
I ran the CS update also...I started from the 7.4. Also I went through the whole 7.4 to 8 upgrade and uninstall a few times with no success.
any thought on why the microsoft visual basic 2005 install part crashes, during the PT LE install..?
Thank you, Jeff |
GET rid of IE 8 for sure.
After doing some updates I get this message on MS OS bootup: " Address a problem with USB Audio Device
USB Audio Device is not compatible with this version of Windows. Digidesign, the company that manufactured USB Audio Device, has informed Microsoft that they don't expect to offer updates to solve this problem. To search for similar devices that are compatible with Windows Vista, go online to the Windows Vista Compatibility Center: " I was hoping this if I replace my laptop hard drive with a 7200prm HD and get firewire out I could do this..? Thanks again...Jeff |
Vista Ultimate, 64-bit, why not? | Bizarro Bluze | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-13-2009 04:22 PM |
Vista Ultimate 64 (the ultimate dissapointment) | Filmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-03-2009 05:44 AM |
Vista Ultimate 64-bit Support for LE 8.0 | belialtheunholy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 04-23-2009 10:57 AM |
64 bit Windows Vista Ultimate and PT LE 7.4 | DdigitalD1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-10-2008 06:35 AM |
Vista Ultimate 64 Bit vs. PT LE 7.4 | SafariSoundFilms | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-27-2007 11:12 PM |
