PTHD Accel 3, Pro Tools 7.3.1cs5, Mac Pro dual 2.66gHz, OS 10.4.10, HD Expansion Chassis, 2GB RAM, Rosetta 800, 96 i/o, Sync i/o, Command 8.
Ever since I moved to my new Mac Pro the plug-in settings do not appear in the Plug-In Setting pull-down menu. The settings are all located correctly in HD>Library>Application Support>Digidesign>Plug-In Settings. I can manually 'import' settings from the folders, but only one at a time. The most pressing and annoyoing manifestation of this is using Access Indigo. Even though I have set the root plugin settings folder correctly it does not recognize the millions of patches which are, quite necessarily, organized by subfolders according to type. Any single setting files not in a subfolder will be recognized once imported. This is a pain. Thank you in advance for your input. |
http://duc.digidesign.com/showflat.p...=965059&Forum=
http://duc.digidesign.com/showflat.p...=967338&Forum= I did a search, see if either of these do the trick. |
locating plug-ins on windows | HiLoc | Pro Tools TDM Systems (Win) | 2 | 07-31-2013 03:34 AM |
"Plug-in Inactive" (plug-in settings lost after upgrade from 7 to 8) | Thyrium | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-25-2010 08:31 PM |
Problem locating plug ins | Chrisostomos | General Discussion | 2 | 08-22-2009 12:46 PM |
Cannot save plug-in settings to Root Settings folder | SimonORorke | Pro Tools M-Powered (Win) | 1 | 01-18-2008 09:38 PM |
Plug In Settings ..... | Doug Farrar | Tips & Tricks | 3 | 10-20-2004 05:16 AM |
