No Signal Generator
Hey Guys,
In Pro Tools 10, inside plug-ins-Other I do not have the Signal Generator listed there. Should it be there automatically, or is this a separate download? If so, where do I get it? Appreciate any help. |
Re: No Signal Generator
Signal Generator is a mono plug-in only, so if you tried to put it on a stereo or multichannel track, you should look into the multi-mono list.
Note : "Other" is the right category, btw.
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD) MacMini (Core i7 Quad@2,3GHz RAM16GB SSD) PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP) PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP) PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD) PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD) RME UFX (USB2 with MM and Firewire with MBP) + Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1 |
Thank you
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
Thanks demodigi for stepping in. So I've added mono Master, Aux, and Audio tracks and still nothing. I even looked under Audiosuite.
Any more ideas? |
I don't know. |
RTAS (.dpm) : Library/ApplicationSupport/Digidesign/Plugins Library/ApplicationSupport/Digidesign/Plugins (Unused) AAX (.aaxplugin) : Library/ApplicationSupport/Avid/Audio/Plugins Library/Application Support/Avid/Audio/Plug-Ins (Unused) Because I don't remind if the RTAS (.dpm) is considered as a legacy plug-ins and so PT installation puts it in the unused folder (personally, it is in my unused folder but I fired up all RTAS plug-ins which also have an AAX version). And please, we need more info about your system (help us to help you) : exact OS type and version, exact version of PT, do you have a co-installation with PT11 or 12, etc... ?
O.k. So I have done what you both have suggested:
Checked .dpm and .aaxplugin and unused folders and still nothing. My Spec are: Windows 10 PT 10 and I have a free upgrade option to PT 11. demodigi, I'm not sure if free upgrade is the same as co-installation? |
I am not a Windows guy but are you sure PT10 is fully compatible with Windows 10 (maybe PT10's installer failed in some ways with Win10)?
By co-installation, I mean : installing PT10 & 11 on the same computer (I was wondering if you did install PT10 AND 11 and then, for any reason, uninstall PT11, because they're both sharing some plug-ins and some settings). Note : - if you install the last version of PT11.3.x, it would also install all AAX plug-ins including Signal Generator which is also compatible with PT10.3.x. - PT need to be installed from an administrator account AND need to be launch as an administrator (right-click on the program and choose this option). - Otherwise try to re-install PT10 with an administrator account (or try to get back to Win7 or Win8.1).
Is Signal Generator gone?! | nz | Pro Tools 9 | 1 | 12-27-2010 07:39 AM |
Signal Generator?!!! | dvuckovic | Pro Tools TDM Systems (Mac) | 5 | 11-01-2007 09:06 AM |
Use of a signal generator | reverieman | Pro Tools TDM Systems (Win) | 1 | 10-25-2006 06:59 AM |
Bug in 7.2 Signal Generator | Craig F | Pro Tools TDM Systems (Mac) | 1 | 10-12-2006 03:17 PM |
Signal Generator gone!!!! | clausiii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-05-2003 03:22 AM |
