Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 02-12-2003, 06:38 PM
where02190 where02190 is offline
Default Re: using Apple Superdrive for audio
If you're asking whether the Superdrive will burn audio CD's the answer is yes. We do it all the time. It seems to burn audio mixes fine.
Hope this is helpful.
Old 02-12-2003, 06:48 PM
DesertDude DesertDude is offline
Yes, usaing a 1 gig Ti. working great. Data DVD's also great.
[img]images/icons/cool.gif[/img]
DesertDude
1.25 Alu/1.5 ram/10.3.4
PTLE 6.4-002R-Live-Reason
Old 02-12-2003, 07:25 PM
davip davip is offline
Thanks for the replies. I guess I should be more specific. I know that the Superdrive will burn audio CDs, but some drives seem to do a better job of this than others.
I spent a lot of time finding a drive/media combo (QPS Firewire/Mitsui gold) that was dependable.
There are 3 main issues:
1. How often do disks fail to be successfully burned? This has never been too much of a problem.
2. How often do disks fail to meet the standards of replication plants. I haven't had much of a problem with this either, but it's probably ultimately the most important issue.
3. Are the disks created able to be played on as many players as possible in the real world. This is the biggest issue. I know that no burner/media combo will create a disk that can be played on every player out there, but my experiments showed me that there is a big difference between different lines of blank media, and that it's important to match the media to the burner.
Has the Superdrive held up well in these regards?
Dual 2.3 GHz PowerPC G5
2.5GB RAM
OS 10.4.6
HD 2 Accel
PT 7.1cs9
192 I/O
Old 02-13-2003, 12:57 AM
Default using Apple Superdrive for audio
Have people been having success using the Apple Superdrives for audio masters?
2.5GB RAM
OS 10.4.6
HD 2 Accel
PT 7.1cs9
192 I/O
Old 02-13-2003, 05:23 AM
1. Using sony Supremas CD-R media, no failed burns except when operator error.
2. Never in over 2 years.
3. No compatibility issues with modern players.
Old 02-13-2003, 06:03 AM
andyo andyo is offline
<font size="2" face="Verdana, Arial">Davip, as I recently found out, there are two things you can do when burning a CD to make it meet and exceed the plants "stress test."
1. Choose "Burn Disc At Once" in Toast prefs
2. Burn at the slowest rate you can afford. If you are making a Master for a plant I suggest 1x.
Andy
Old 02-13-2003, 01:32 PM
Where,
Thanks for the info. It sounds like I won't need my Firewire drive when I get my new machine.
Andy,
Definitely Disk-At-Once is the way to go. I use Jam, which is DAO only. There seems to be a bit more debate about the best speed. Some say burn at 1X, some say burn at 2X, some say burn at the fastest speed your burner will support. For example, Digi's documentation for Masterlist CD recommends using the fastest speed available. At various times I've subscribed to all three theories, and I've had no problems with replications of masters burned at 1X, 2X, and 8X. The biggest factor seems to be correctly matching burner and media.
Cheers
2.5GB RAM
OS 10.4.6
HD 2 Accel
PT 7.1cs9
192 I/O
Old 02-13-2003, 09:48 PM
john haze john haze is offline
Anyone know when WaveBurner Pro will be OSX compatible??
jh
Old 02-14-2003, 08:48 PM
Zumwalt Zumwalt is offline
By the way, the Superdrive does not support CD Text. If you want your CDs to have the name of the CD and each track's name come up in the display of the CD Player, you need something else.
(Yamaha CRW F-1 w/Waveburner Pro) Although not OS X yet, Emagic is owned by Apple so I assume (there I go again) it will be soon.
John Zumwalt Stephan
SpringsTheatre.com
SpringsTheatre.com
Old 02-15-2003, 11:43 AM
Jan Folkson Jan Folkson is offline
<font size="2" face="Verdana, Arial">Don't get rid of your firewire CDR just yet. While the superdrive does a fine job of creating CD masters, it's not the zippiest when you're in a hurry or just printing refs. You don't mention how fast your firewire drive is but I bet it can burn data CDs way faster than the superdrive.
- Jan Folkson
www.janfolkson.com
Need a replacement for Apple Superdrive! fingerz88d Storage Subsystems 2 12-19-2004 09:48 AM
compatable w/Apple Superdrive? Rams Boy Digidesign Hardware & Software 1 06-10-2003 11:44 AM
Does Jam 2.6 support the Apple Superdrive? AlanB Pro Tools TDM Systems (Mac) 10 04-24-2002 03:13 PM
DVD-R burning with Apple Superdrive tdmguy Pro Tools TDM Systems (Mac) 8 01-31-2002 09:51 AM
Can anyone play DVD's on Apple SuperDrive???? Ozzyboy Pro Tools TDM Systems (Mac) 10 04-10-2001 10:25 AM
