Old 07-02-2015, 07:06 PM
mattz63 mattz63 is offline
Default Midi Footboard Expression Pedal (CC 11) and External Footswitch Mutally Exclusive?
My Art X-15 Ultrafoot MIDI pedal board has 2 rocker pedals, one of which I have assigned to CC11 (for expression). This is very versatile and convenient; I'm impressed with the options for assigning controls per patch in the 11R editor. However, it seems that when I plug in a foot switch into the external pedal jack, I can no longer use the Expression assignments--even though the expression control is coming from MIDI in. Am I missing something here, or is this...um...a "feature?"
Old 07-14-2015, 09:11 PM
Default Re: Midi Footboard Expression Pedal (CC 11) and External Footswitch Mutally Exclusive
Anyone? I'm not sure why I can't use my MIDI Expression Pedal--going into the MIDI In on the 11R, and set to CC #11--and the footswitch jack at the same time.
I have the Exp. Pedal set up for MultiFx, but it seems to lock me out from simultaneously using the dual footswitch mode.
ErnieBall VP Jr Volume Pedal as expression pedal. cohensm Getting Started 7 07-06-2014 07:48 PM
DB-33 expression pedal assignment johnwott Virtual Instruments 0 06-07-2012 10:50 AM
Mission EP-11 expression pedal PBGas Eleven Rack 5 04-10-2012 12:28 PM
Expression pedal with PT8 phiffdawg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-03-2011 08:29 AM
Using expression pedal with ProTools phiffdawg MIDI 0 01-19-2011 12:41 PM
