Old 01-19-2011, 12:40 PM
phiffdawg phiffdawg is offline
Default Expression pedal with PT8
Okay what am i missing here? I just bought a Boss fv-500h pedal. When I plug it into my Axiom MIDI keyboard I can't get the pedal to do anything in Xpand and Structure and I get no sounds coming into Protools. when I unplug the cable everything works fine.
Anyone know what the problem is? Does this pedal not work with Protools?
Thanks,
Phiff
Old 01-19-2011, 01:31 PM
nst7 nst7 is offline
Default Re: Expression pedal with PT8
Are you using the jack on the pedal that says "exp" (for expression) as opposed to the jack that says "output"?
Old 01-19-2011, 03:56 PM
yes.
Old 01-19-2011, 06:54 PM
Have you tried Option-clicking on a parameter in the plugin, selecting Learn, and working the pedal?
Old 01-22-2011, 10:57 AM
When I do that with the volume parameter not much happens. Strangely the only response I get is a slight rise in level when I "unpress" the volume pedal. The opposite reaction I would expect. The level is really low and inaudible though.
I just unplugged the cable and get no sound now even thought the pedal isn't plugged in.
Any thoughts on where I should go to solve this issue?
thx,
C
Old 01-22-2011, 02:53 PM
I think I have found the problem. I am using a mono 1/4" cable and should be using a stereo one...
C
Old 02-03-2011, 08:29 AM
Just to comfirm: the problem was that I was using a mono cable instead of stereo (duh).
thanks
DB-33 expression pedal assignment johnwott Virtual Instruments 0 06-07-2012 10:50 AM
Mission EP-11 expression pedal PBGas Eleven Rack 5 04-10-2012 12:28 PM
Expression Pedal observations Jermak Eleven Rack 3 04-25-2011 07:04 AM
Using expression pedal with ProTools phiffdawg MIDI 0 01-19-2011 12:41 PM
Expression pedal > Rig Volume > on To Amp out as well? therealmf Eleven Rack 5 10-17-2010 11:55 AM
