Old 09-26-2006, 10:58 PM
Armando Armando is offline
Default No audio from Apple Apps. Core Audio problem?
For whatever reason, I can no longer get apps like iTunes or QT to playback audio when PT is shutdown(192I/O). Before, I would just get a spinning beachball for a while and then the app would function/playback audio. Also, I now see that launching Apple's System Preferences causes Core Audio Manager to launch(and spinning beach ball). I trashed CoreAudioManager pref. but that did nothing. Everything was fine up until 2 days ago. Anyone know a fix? G4 Dual 1Ghz MDD, OS 10.4.7 and PT 7.2.cs1.(HD3).
Armando
Old 10-08-2006, 09:51 PM
Willard Willard is offline
Default Re: No audio from Apple Apps. Core Audio problem?
Similar problems here. Since installing 7.2, regardless of how I set the system "audio" preferences, CoreAudio launches when a browser (Firefox/Safari, doesn't appear to be browser specific) browses to an audio file. The browser then gets the spinning beach ball and if you open the "force quit" window, you can see the browser is "not responding," for a good 10 or so secs. Then the browser rights itself and gets back to work.
I don't want CoreAudio to launch and in all versions up to 7.1cs9 this was not an issue. CoreAudio also loads for me too (why?!!!)when I open the "System Preferences" which also causes that to get dizzy for 10 secs or more. I always use the Mac Audio out for the system audio, so I don't need CoreAudio. Can I disable (trash) it? It's only necessary when not using DAE?
I only get this problem on the g5 2.3/pci-e/10.4.7/192io, not on the g5 2.3/pci-x/10.4.7/apogee rosetta200.
Thanks
Kevin
hd3/7.2cs1/192 i/o
control24
g5 2.3 dp pci-e/4gb ram/10.4.7
hd3/7.2cs1/rosetta 200
g5 2.3 dp pci-x/5gb ram/10.4.7
Pro Tools 9.0.5 | HD3 PCIe | 192 i/o | C|24
Mac Pro5,1 (mid 2010) Westmere 3.33 GHz Hexacore | 16gb ram | OS X 10.7.4 | VEPro 5.3.13141
Pro Tools 9.0.6 | HD3 PCIx | Apogee Rosetta 200 | Magma PE6R4-I
MacPro5,1 (mid 2010) Westmere 3.33 GHz Hexacore |16gb ram | OS X 10.7.4 | VEPro 5.3.13141
Old 10-09-2006, 08:03 AM
Try using the PT 7.2 Uninstaller. Then install 7.1cs9 including the Core Audio Manager and then install PT 7.2 and make sure Core Audio Manager 7.2 is unchecked. See if that does solve those problems.
I actually emailed Digi TS on this and got a prompt reply telling me this behavior is pretty much normal. It's not. The CAM for 7.2 needs to be fixed. Until then, just use 7.1cs9's CAM.
Armando
Old 10-09-2006, 08:08 AM
By the way, there's another post of mine on here somewhere where I discovered this issue with the 7.2 CAM by doing some simple troubleshooting. Just try that and see if it doesn't eliminate your issues as it did for mine.
Armando
Old 10-09-2006, 11:10 AM
I had a clone of the drive before I did the 7.2 upgrade. So I tried a quick swap with an older (7.1) Core AudioManager. No joy. But I did check out the suggestion by Noiz2 from your other post on this subject (Re: Digi TS: Problem w/current Digi Core Audio Manager) and changed the Core Audio to 48kHz. Problem solved!! This avoided the whole reinstall, which as PT itself is running nicely, I didn't really want to mess with.
I can now reproduce the behavior on the pci-x machine with Sysetm Preferences/Sound/Line Out - Built-in Audio;
Browsing with CAM set to 48kHz, CAM doesn't load (good).
Browsing with CAM set to 44.1kHz, CAM loads (bad).
Thanks for the help.
Kevin
Old 10-11-2006, 10:08 AM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
Please try trashing the following files from MacHD>Users>your account>Library>Preferences:
com.digidesign.coreaudiomanager.plist
DAE Prefs
DigiSetup.OSX
Empty the trash and restart - do you still have the same problem?
Also let us know what files and version numbers are in the folder located at MacHD>Library>Audio>Plug-ins>HAL.
Avid Audio Tech Support
Support FAQ
Old 10-11-2006, 06:22 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
I used to have this problem all the time with 6.9! Sonic Studio's DDP or soundBlade would NOT open DigiCore, even JAM wouldn't work. After doing all the official updates, I don't even have to think about it and everything plays through the hardware. I just figured someone finally had a conference call to figure it out!
Sorry this doesn't help your situation, but it's all working for me!
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 10-12-2006, 11:34 PM
Trashed all the prefs suggested, as I do regularly.
Still have the same problem. Well, it's not actually a problem anymore, cause I just set the CAM to 48kHz and everyone is happy.
MacHD>Library>Audio>Plug-ins>HAL.:
Digidesign CoreAudo.plugin (7.2)
iSightAudio.plugin (7.1.3)
Thanks
Kevin
Old 10-16-2006, 09:02 AM
I did all you suggest(trashing Digi items in Preferences folder) before I found the issue with the 7.2 CAM so I'd rather not update my current 7.1 CAM to 7.2. Here are the items and file numbers located in the HAL folder: Digidesign CoreAudio.plugin Version 7.1 and iSightAudio.plugin Version 7.1.3.
Hope that helps.
Armando
Old 10-16-2006, 12:34 PM
jouLe jouLe is offline
I am having a similar problem with my ProTools 6.4
iTunes won't play songs at all, though otherwise works fine. My preview in the finder will play the songs, but there is no sound. When I go to SystemPreferences>Sound>Output (and Input), the only device available for choosing is Digidesign HW, and I am told the selected device has no (input/output) controls.
I am also having issues with startup, and my log says: DigiCoreAudioDriver> Found 9 entries in 'SupportedApps.txt' repeatedly. It seems to continue finding this throughout my computer session.
What the heck happened to my Built-in Audio?
Oh, and the files at MacHD>Library>Audio>Plug-ins>HAL are as follows, in case it matters:
DigidesignCoreAudio.plugin Version 6.4 (C 2003-2004 Digidesign)
iSightAudio.plugin Version 6.5.1 (C Apple)
Thanks!
Core Audio Apps have a delay michael c Pro Tools TDM Systems (Mac) 4 02-02-2010 09:28 PM
core audio/3rd party apps codfish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-16-2005 03:46 PM
Apple DVD Player/Core Audio static problem Armando Pro Tools TDM Systems (Mac) 1 01-14-2004 03:34 PM
Can two apps use Core Audio at the same time? willson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-01-2003 07:58 AM
Core Audio (Limiting which Apps can use it.) carouzal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-19-2003 08:49 PM
