Old 06-18-2005, 04:16 AM
jiggy_bau jiggy_bau is offline
Default S-MUX / Double Speed / Double wire
Does Pro Tools support s-mux stadard? I.e. can I stream digital audio at 88.2/96 kHz? I have a HD 3 Accel system with two IO 192 interfaces. While we're at it can Logic Audio do this? And one more thing: is s-mux the only standard for streaming 88.2/96k signals over ADAT optical? I'm asking this because I have a lot of hardware from different manufacturers (e.g. RME ADI 8 DS converter, RME HDSP 9652 card, EMU 1820m card, Creamware A16 Ultra converter, Creamware pulsar 2 card etc.) and I wonder if these devices support the same standard.
Thanks!
Kids, don't try this on a Mac [img]/images/graemlins/grin.gif[/img]
Old 06-18-2005, 04:46 AM
clusterer clusterer is offline
Default Re: S-MUX / Double Speed / Double wire
as to S/MUX: unfurtunatly - PT doesn´t support S/MUX - anyway not for 96 I/O. perhaps for 192 I/O.
i´d also would welcome it!
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 06-27-2005, 09:24 AM
Thanks, clusterer. However I'd like to get confirmation from digidesign administrators, please.
Old 06-27-2005, 09:36 AM
yelhahc yelhahc is offline
This is a pretty expensive solution, but a few of the Apogee interfaces support S-MUX, including the Rosetta 200. They can be used directly with Pro Tools with the addition of an X-HD expansion card (they appear to Pro Tools as a 192 interface).
Steve.
Help, Double speed WITH pitch change? brizpaul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-28-2011 08:05 PM
Recording at Double Speed teacherman Tips & Tricks 10 09-30-2008 06:26 PM
Playback at double speed / higher speed in LE? Chris Nelson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-26-2008 09:28 AM
play double speed? Audio Princess 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 06-20-2005 10:57 AM
96khz via double wire from PSX-100 REDD 37 Tips & Tricks 1 05-24-2001 04:32 PM
