Old 07-09-2004, 10:32 PM
Johnny916 Johnny916 is offline
Default HELP with Digi 002 ALT monitor outputs?? NO VOLUME
Hi, I have two sets of studio monitors. I usually use my Event PS8's connected to main outputs and of course the volume and mute buttons works perfectly with them.
However, I just bought some Event TR5's and plugged them into the Alt monitor outputs and I have no control over any volume levels or mute levels on them.
I want to be able to switch back and fouth between the two sets of monitors to hear my mixes from two different perpectives. How can this be done from the Digi 002 CONTROL SURFACE?
Thanks, John..
Never underestimate the predictability of stupidity!
Old 07-09-2004, 10:42 PM
mpark9000 mpark9000 is offline
Default Re: HELP with Digi 002 ALT monitor outputs?? NO VOLUME
I use the Alt outputs on my 002 without any problems. Is it the channel faders that have no affect, or the Alt master level knob? Have you pressed the "mute" button so it's dark? It will always be muted by default everytime you start up the board.
"They may call it walking in Texas, but in California we call it just being a jerk"
Old 07-09-2004, 10:45 PM
It's certainly not muted. I've pressed everything. I tried turning down the master volume with the alt src mon button lit as well. Nothing seems to work, I cannot control the ALT monitors.
Thanks, John..
Old 07-09-2004, 11:00 PM
Either the board is defective, there's a wiring problem, or operator error. The Alt outputs work fine on my 002.
On a functioning 002, with correct wiring, you can control the output volume and mute as you would expect. I don't mean to imply that you aren't intelligent, I have done (and will do in the future) much dumber things than overlooking the obvious.
Old 07-10-2004, 07:33 AM
Pick up a Samson C-Control ($99) or similar device to switch between monitors and use monitor outs only.
Digi 003 Rack Monitor Volume - crackling pot GordonFreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 39 08-29-2022 05:39 PM
Digi 002 static/distortion from Monitor Outputs and Headphone jack CyberTribal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-22-2013 07:31 PM
Digi 002 Monitor Outputs elandrue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-21-2009 07:04 AM
Digi 002 monitor outputs balanced or unbalanced? coryc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-19-2004 07:22 AM
Monitor Outputs - Digi 001 woodman01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-08-2002 04:14 PM
