Trouble with Strike 1.5 Install from download
I purchased and downloaded Strike 1.5 Upgrade (I was previously licensed to 1.0). I got the iLok key fine, and downloaded all files.
I have them all in a single directory on my "C" drive, and unzip all the content into a folder. I run the "content location" program, and it sets fine. I start the Strike installer, and it goes fine until it gets to the point where it asks for "Strike Content 1" folder. I select the folder where my content is, but I get an error stating "setup could not find a valid file in the path". It doesn't tell me what sort of file it is looking for, so I'm not sure what it needs. I try to cancel the error and continue install, but the installer doesn't allow that. I tried the install a second time, and wanted to skip the content install. I figure I could just point to the content afterward. However, the isntaller won't allow me the uncheck "content" - I'm forced to install both. I was really hoping to get this going tonight, and verion 1 installed without problems. Kind of frustrated. My system info: Windows 7 64 bit 6GB RAM, and 1TB drive Digi 003 Pro Tools LE 8.0.3 running fine Thanks for any help you can provide. Hammster |
Re: Trouble with Strike 1.5 Install from download
I've had a Strike install issue as well - downloaded all 4 .dmg and the system says "Successful" but when I launch PT1- it says "Pro Tools could not load the following plug-ins because no valid authorization could be found, the iLok key was not connected or the plug-in was damaged". I already downloaded the auths to my iLok and verified they are there. Weird!
The Voice of Brian Mac Studio M1 Max, Focusrite Clarett2Pre, Sennheiser 416, sometimes Beta Tester for iZotope |
Same here.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4 |
I ran the PT10 installer again and it's fixed. DTS needs to make a sticky about this.
worked for me!
When you guys ran the PT10 installer again, did you uninstall it first and then reinstall? I might give it a try if so.
SUCCESS!!!!!!!! Hammster, I uninstalled PT10 and reinstalled. It came right up!!! I do see it flashing a note in the bottom of Strike saying I need to "run the SetContentLocation application"......I see what's up with that now. But hopefully this will fix your issue as well.
Download trouble | Councillor | Getting Started | 1 | 09-10-2013 12:26 PM |
opening download of strike on mac | paul sandberg | Virtual Instruments | 3 | 11-12-2011 01:41 PM |
8.04 LE Download Trouble | lovesciencemusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-10-2010 09:33 AM |
Strike download for PT 8 ? | Majorek | Virtual Instruments | 2 | 06-08-2009 12:15 PM |
Strike Trouble | tclopet | Virtual Instruments | 2 | 01-06-2007 06:38 AM |
