Old 07-01-2008, 10:05 AM
crizdee's Avatar
crizdee crizdee is offline
Default Automation problem with and between matching break points
I have several sections of automation that i can't move separately although the break points at each end are matched. when i hover the trim tool between the 2 matching break points it moves the automation for the whole track!
You can see on this video. the long section has 2 break points at each end and both are exactly -0 db the short section has 2 matching break points both 1.4 db. even when i create 2 new matching break points of -0 db it still won't select just that area
you tube http://www.youtube.com/watch?v=hghcibUM9Fc
hi res download .mov http://www.sendspace.com/pro/dl/trtg7a
Its always bugged me that you can't grab a section between 2 break points and move it up or down an exact amount whilst keep the relative level differences. without having to re-select the area!! which then keeps creating more break points, causing the faders during playback on my control 24 to jump around like a demented chicken with its head cut off.
unless i've missed it? is there a way to do it, just select between break point on the right and break point on the left and move up or down in an equal amount.
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-01-2008, 10:24 AM
DigiTechSupt's Avatar
Default Re: Automation problem with and between matching break points
Is this happening on every session or just on certain ones?
You should be able to use the Trim tool to click and drag above two equal breakpoints to move just the section between those points.
I can't reproduce this unless I'm putting the cursor directly over a vertical breakpoint line before dragging.
Is there anything else that may be a contributing factor?
Avid Audio Tech Support
Support FAQ
Old 07-01-2008, 12:38 PM
crizdee's Avatar
It works fine 99.9% of the time just occasionally i get this behavior.
I can find or think of any contributing factors!
Only workaround is to reselect the area! but after 3-4 amendments it looks like a shoot out a OK Coral
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-01-2008, 02:55 PM
2fly 2fly is offline
I've come across this too. I've taken to separating the region (when I highlight the part I want) cos it makes it a lot easier to do quick edits and a quick double click gets the exact same area selected.
Alan
http://www.2flystudios.com
G5 2.5ppc, 4gb ram, OSX 10.5.8, PT8.0.1cs4
Old 07-01-2008, 03:31 PM
crizdee's Avatar
Yes i do that to occasionally, and it works on audio tracks if you want to automate an exact phrase, but if you want to automate just part? plus my problem is on a aux bus!
I would just like to be able to select a section between 2 break points and move it up or down at equal volume from both points! the whole section up 2db or down 3db regardless of whether there is a slope in the automation or not. it seems unless you have an exact straight it has to be re-selected every time! hence by the 5th remix its got 50 break points for each word!
Chris
Producer, Engineer,
www.ukmastering.com
Old 07-01-2008, 05:59 PM
Aquarius Aquarius is offline
I'm gettng this also quite often.
Seen it on many different versions 7.2/3/4...
Cheers;
A
Old 07-01-2008, 09:23 PM
JGuth JGuth is offline
I have seen this also.
Also the trim should be fixed so as to NEVER create ramps. For me this behavior is never wanted.
Old 07-02-2008, 10:32 AM
Can any of you send us a session that exhibits the problem?
Send it to transfer [at] digidesign [dot] com. Please include the subject of this thread and the thread number (1296621) in the subject of your email.
Support FAQ
Old 07-02-2008, 02:07 PM
Taliq Taliq is offline
I always tought it's just how Pro Tools handles automation. I have the problems in almost every session. Sometimes it works, but most of the time it doesn't.
Studio:
PPC G5 Dual 2.7GHz, 4GB DDR SDRAM, Mac OS 10.4.6
Pro Tools HD 7.1, 6 DSPs, 4x192 i/o
SSL 9000 J-Series
Private:
MacBook 1.83 GHz Intel Core Duo, 1GB DDR2 SDRAM, Mac OS 10.5.3
Pro Tools LE 7.4.2, MBox
Old 07-03-2008, 07:25 AM
Could it be, that Pro Tools does it, because the breakpoints are not on the same level? I played with it a little bit and found, that the level has to be the same on both breakpoints to trim it with the trim tool without a selection.
Studio:
SSL 9000 J-Series
Private:
Matching automation points for volume trims JohnCatlin Pro Tools TDM Systems (Mac) 2 10-06-2010 12:39 PM
PT 8 Automation Break Points myke2242 Post - Surround - Video 7 04-20-2009 10:17 PM
Track flashing white when editing automation! break points in PT8 crizdee Pro Tools TDM Systems (Mac) 9 01-29-2009 02:01 PM
dragging break points Khatru 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-18-2007 05:41 PM
Adjusting automation between break points question crizdee Pro Tools TDM Systems (Mac) 5 08-02-2005 01:39 PM
