  #21
Old 04-27-2020, 01:47 PM
JFreak JFreak is online now
Default Re: Pro tools 2020.3 Crazy Cpu and Ram %
Your problem may be right there; exact same version of the plugin may not work well with newer PT version, so you need to wait for 3rd party to release a plugin version tested against the PT version you are using now.
  #22
Old 04-27-2020, 01:57 PM
crandallwarren crandallwarren is offline
Isn't that the purpose of having the dedicated AAX format? That... all AAX plugins will work with Pro Tools? Is there a new version of AAX in 2020.3?
  #23
Old 04-27-2020, 02:09 PM
Any plugin that runs on general-purpose processor (as in native processing) is dependent of the build of plugin and build of host software. These need to match. If you change one, you may need to change the other as well. Always update plugins to new versions whenever you update PT.
DSP is different. Once you have a perfectly working DSP plugin you only need to change it when they change DSP hardware.
  #24
Old 04-27-2020, 02:17 PM
Talking Re: Pro tools 2020.3 Crazy Cpu and Ram %
Well, if the responsibility lies with the 3rd party to adapt to the larger-- where's Pro Tools video support for CATALINA? :)
  #25
Old 04-27-2020, 02:28 PM
Havent you read the release notes? Some will work, but not everything. What works is working better than before but sure if you rely on codec that isnt working you need to keep waiting ot adopt another video format in your workflow
  #26
Old 04-27-2020, 05:37 PM
I know what works and what doesn't work. There's a lot that doesn't work. And Catalina was released 6 months ago...
All I'm gonna say is this:
In regards to what I said regarding Avid support being a "joke". I stand by that comment 100%.
The OP said he emailed support and received no response. I have had the same experience. And the difference is:we pay for it. We pay a yearly fee for support. I can understand if it was a complimentary service. But it's not... And yet, every time I have to contact support with an issue-- I receive either no support or very little.
I also want to point out that this is my experience with Pro Tools support. I'm also a console user and I've received fantastic emergency support for the SC48 and S6 systems.
So, I guess my question is... When it comes to Pro Tools... Do you guys have to be so... Avid-esque ? Is it really beneath your support team to assist your customer base with these types of issues? Is it too much to ask that you support not just with the functioning of Pro Tools in a vacuum, but the workflows we've built around it?
Is that too really too much to ask?
  #27
Old 04-27-2020, 05:40 PM
No you are spot on, it is not acceptable if support drops the ball. We have had to escalate many caes recently. Not sure if it is because of this covid **** but anyway, recent weeks have been a disaster
  #28
Old 04-28-2020, 02:38 PM
bartosz idzi bartosz idzi is offline
I have always received my (due) support when using Support Portal (not emailng but creating support case). And even sometimes the ball was dropped by me not knowing the software/conflicting configuration of Mac OS.
My Avidesque 2 cents. :)
Mac Pro 2 x X5690 3.46Ghz - 64 Gb RAM - SSD 256 Gb - SSD 1TB - OS 10.14.6 - Metric Halo 2882 + Lucid 88192 - Pro Tools Ultimate 2020.11
  #29
Old 04-28-2020, 02:42 PM
clivvy clivvy is offline
its a moon shot but i hope one day we will have a close to perfect protools DAW!
  #30
Old 04-28-2020, 02:53 PM
So called perfection for me was PT 8.1.1 HD on OSX 10.6.8 -- so far the most stable and reliable system ever.
But it does not have Disk Cache, does not have Write Automation on Record, does not have current metering, etc...
Point being that PT8 era it was crucial to have a stable system to be able to record a 3 hour live gig. Without disc caching needed to test stability after each and every update. That has changed for good, but of course when you fix something, then something else is broken and you are never satisfied.
Unless you take the stance you are happy as long as you get your job done.
Pro Tools 2020.1 off the wall Pro Tools 2019 141 11-28-2022 01:59 PM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
Cannot install Pro Tools 2020.3.0 on Catalina in any which way moyno85 Pro Tools 2020 3 04-04-2020 03:41 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
