Old 01-23-2022, 02:41 PM
Vercingetorix Vercingetorix is offline
Default Eleven Rack Editor problem?
Hello all,
I am having a problem with the Eleven Rack Editor on my Win10 system. The problem is the software opens but the window is not appearing onscreen! It did the first couple of times and I was thinking ahhh,the new computer fixed that particular problem, but, no it's gone again. My older system had a way of fixing this by going into users/myName/Appdata/Avid and deleting the Eleven rack editor directory turning off the 11R and turning it on again and presto the directory would reappear and the program would work for at least the next 3 times before having to do it again.
But on my new system there is no Avid directory. So if there any way of getting the Window to reappear. I tried deleting and re-installing the software and didn't work.
Any ideas as to what to try?
As always any help is greatly appreciated.
V.
You're validating my inherent mistrust of strangers.
Schecter Hellraiser 7 Diamond - Ibanez RG7620
Eleven Rack w/ ERXP
Old 01-23-2022, 03:05 PM
Default Re: Eleven Rack Editor problem?
So you used to do this: https://avid.secure.force.com/pkb/ar...s-systems-only
And that's not working now. Likely because the Editor is not fully starting up.
Try searching for other tips on DUC about this. Use google but add
site: duc.avid.com
To the search string. and use "Windows 10" and "Eleven Rack" with quotes to force only Windows 10 related results and go from there.
Try running in Windows 7 compatibility mode will be one thing to try.
There are multiple potential issues that folks have run into and documented how to work around on DUC.
e.g. this beauty about missing DLL support: https://duc.avid.com/showthread.php?t=380144
But that's just an example. Google search will find you the history of things, and don't give up by trying just one thing, or assuming folks telling you one fix they used will work for you... there are multiple things to try to work though.
There are other folks (esp. Benoni) here who are very knowledgeable about the editor on Windows. Praying to the Benoni gods might help.
Old 01-23-2022, 03:57 PM
Benoni was the person that I got the workaround from. So Benoni is likely a dead-end. I think he has moved onto using other more professional gear - he would no longer use an 11R.
About the only thing I can try finding is an app that will force it to start on the default screen rather than offscreen - possibly. There WAS a link to something that did that, but, no longer works.
Eleven Rack w/ ERXP
Old 01-23-2022, 04:05 PM
My brother who was over started stuffing around with the computer and got it working somehow??? Don't know how, but, he does that sort of thing - I drive them into the ground and he resurrects them!
Eleven Rack w/ ERXP
Old 01-24-2022, 04:02 PM
Another thing I have found curious is that now that the 11R window is active and working that there is no Avid folder located at:
  • users/myName/Appdata/
on my Win10 system, so that workaround created by Benoni will no longer work. I mean I was lucky that my brother got it working this time, but, if it's anything like the Win8 system it will happen again. It used to disappear about 25% of the time.
Eleven Rack w/ ERXP
Old 01-30-2022, 06:46 PM
LeMarquis LeMarquis is offline
Thx a lot, delete content in AppData folder work for me !
Old 01-31-2022, 01:20 AM
L-Dogg L-Dogg is offline
You seem to know what you are doing so this might be an incredibly stupid suggestion on my part. My MacBook Pro sometimes does this. I click on the Editor in my dock and it opens but I don’t see the GUI open up.
I have to go to the Eleven Rack Editor toolbar and under Window or View or something, click on Show Editor. Then in opens. Most of the time.
Sorry I’m not at my setup so I forget exactly what it says. But when I click on that my editor GUI opens like it should do automatically…….but randomly does
not.
Rarely…….even that doesn’t work and I have to restart the computer. Sometimes I get an error saying connunication is lost between the computer and Eleven Rack even when there is no problem with the USB cable. Mostly closing the app and then re-opening sorts it out. Weird though!
Good luck sorting it.
Mac Studio M2 Max
12-core CPU, 38-core GPU, 16-core Neural Engine
64 GB memory
2TB Solid State Drive
Thunderbolt 4
Sonoma 14.1.2
Pro Tools 2023.9
Universal Audio Apollo 8P (TB3 Option Card installed)
Now that Eleven Rack drivers work in Catalina, does Eleven Rack Editor also work? JoeM Eleven Rack 5 04-26-2021 12:18 PM
Eleven Rack Editor 57Stratocaster Eleven Rack 4 08-22-2016 11:12 AM
Eleven Rack Editor joeleemusic Eleven Rack 2 06-07-2014 08:12 PM
