Old 10-18-2003, 12:07 PM
L.A.P. RECORDS L.A.P. RECORDS is offline
Default BOOT FAILURE
I am using protools digi 001 5.3.1 XP. I recently upgraded to XP and it was runing fine. It froze during playback and gave me a DEA error message. I rebooted the PC and it did not boot back up. It says BOOT FAILURE insert BOOT diskett in A drive.
Can someone please tell what I need to do. Its searching the floppy, CDROM, IDE-O, SCSI and all are saying not found. Am I in trouble of losing my recordings and files? What happened?
myspace.com/eklazz
myspace.com/greatdamemusic
Old 10-18-2003, 12:45 PM
Default Re: DEA ERROR
What was the DAE error number?
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-18-2003, 01:13 PM
I'm not sure.. it ask to me to check the size.. I think it was set at 1024.. but I can't get back on to windows to check that because the system won't reboot...?????????
Per my original post!!
myspace.com/eklazz
Old 10-18-2003, 01:23 PM
Can you start up in SAFE mode?
Rail
Platinum Samples
Old 10-18-2003, 02:15 PM
not sure how to do that?
myspace.com/eklazz
Old 10-18-2003, 04:45 PM
Boot XP into SAFE Mode
Rail
Platinum Samples
Old 10-18-2003, 10:59 PM
scoobydoo scoobydoo is offline
If you can't boot in safe mode it looks like two things.
1. Boot sector corruption... in this case you might be able to restore a boot sector from a previously saved backup if your HD uses a formating utility that allows this function. (like western digial I believe).
2. Hard drive failure..... what can I say.... bad news..... everything lost unless you want to send it too a data recovery service. Had this happen to me recently with a Maxtor drive. One of a long history of Maxtor drives failing with me. Lost everything that wasn't backed up. %^$& happens.
Do you have another drive in your box? If so, you MIGHT try to install on OS like XP on that drive and see if your screwed up drive can be recognized by the other. If so if you can transfer the session data to another drive (within windows) even though the OS can't boot on the original drive. I do this. (keep an os installed on my other drive.) Saved a session lately.
You gotta get it in the mic!
OT: PT-Win 7 / XP Dual-Boot; Question re: Win 7 Install, Boot Manager Files taylor4814 Windows 1 02-16-2012 05:54 PM
Switching System Drives -- Disk Boot Failure? JamLewis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-09-2010 03:58 PM
could addtlmix farm card cause boot drive failure? c-post Pro Tools TDM Systems (Mac) 0 11-18-2006 12:10 AM
Boot failure- Mac OS ROM checksum failure...SCSI shaggy Pro Tools TDM Systems (Mac) 11 06-23-2000 03:30 PM
Mac OS Rom Boot Failure! Anyone experience this one? shaggy Pro Tools TDM Systems (Mac) 2 06-11-2000 12:57 AM
