Old 03-27-2008, 05:04 PM
Chill Chill is offline
Default Control 24\"s Fader Motor Digi-Tech
What would I be looking at as far as getting a new motor for my faders on the Control 24? My faders are sticking, then jumping around, and just plain going haywire. It seemed to come under control when I turned it of from the switch on the back, then back on after a few minutes. However, my happiness was very short lived. What's the problem and where can I get it fixed in Houston Texas?
Chill
Old 03-27-2008, 05:21 PM
BradLyons BradLyons is offline
Default Re: Control 24\"s Fader Motor Digi-Tech
Control24's need to go back to Digi for repairs, AFAIK. I'd contact them about that right away. Have you done a hard-reset?
Thank you,
Brad Lyons
www.howavl.com
Old 03-28-2008, 03:03 PM
Studio Dweller Studio Dweller is offline
Doesn't each fader have it's own motor? You can buy individual replacement Control 24 faders here:
Digistore: Control 24 Replacement Fader
Larry
Cellar Dweller Productions
PT 2020.3.0 HDX, HD IO 16x16 analog, 192 I/O, Control|24
Mac Pro 2019 16-core, 96GB RAM, OS 10.15.2
Old 03-28-2008, 06:46 PM
Shawn Simpson Shawn Simpson is offline
If it's a lot (or all) of your faders and it came on suddenly, it's probably not a motor. It's probably the fader control board. Does this Control|24 have the updated power supply? I can't remember the serial designation but if your power supply has a fuse holder next to the IEC connector then it's the old style. The fader control boards are replaced along with the power supply. If you're not sure, you might just call customer service and check with them. It was a free replacement, but a pain in the rear end to install.
Digi Tech Support: Control|24 Clicking Noise on Power On Krumbz ICON & C|24 14 05-19-2012 11:41 AM
Motor Fader Firmware gone diegogat ICON & C|24 1 09-16-2008 10:26 AM
DIGI TECH - READ THIS PLEASE - 002 Fader Support IntelDoc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 07-18-2006 10:14 PM
Multiple Motor Mix problem (Tech Support) Chronos Pro Tools TDM Systems (Mac) 5 12-04-2001 06:22 AM
tech suppt pleeze-motor mix trouble thumbolt68 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-27-2000 05:03 PM
