Old 07-26-2022, 12:24 AM
sean shannon's Avatar
sean shannon sean shannon is offline
Default Re: iLok USB connection on thunderbolt laptop?
Thanks Darryl. I'm just getting into Pro Tools on a mac laptop, so I appreciate the tips!!
Check your mix in mono.
www.mixingtheband.com
Old 07-26-2022, 05:44 AM
dominicperry dominicperry is online now
If you want a genuine Thunderbolt dock (rather than a USB dock) then you shoudl consider the Caldigit range.
Be aware that there a limitations with all of these docks - for example, in the case of the widely used Caldigit TS3+, the Ethernet port is only 1Gb/s and does not support AVB (which you would need for Carbon).
More significantly, for most people, there are always limitations as to how many screens, what resolution and what refresh rates can be supported across multiple ports on the dock, given that all the ports are fed from the bandwidth of a single TB port.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 08-03-2022, 11:33 AM
andrealc andrealc is offline
I’m also on a 2019 intel macbookpro 16”
After a little search in 2020 i bought this usb-c hub that is doing fairly well, ilok included👍
CharJenPro USB-C Hub USB-C 3.1...
https://www.amazon.it/dp/B01MXKJC4M
Old 08-03-2022, 01:44 PM
Ok sorry leave the ‘also’ i’m on a 2019 macbookpro.. 😂
PT loses connection to Thunderbolt/Apollo Twin manyrains Pro Tools 2020 0 05-16-2021 06:50 AM
HDN Thunderbolt & Windows Laptop Caslon Pro Tools HDX & HD Native Systems (Win) 33 07-22-2015 07:24 AM
Digi 001 connection to Laptop Dogmatic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-21-2006 02:15 AM
OO1 G4 Laptop SCSI to PCI connection Big Smile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-12-2005 02:01 PM
having trouble getting a connection w/Ti laptop Fritz ProControl, Control|24, Command|8 1 02-26-2004 06:29 PM
