Old 04-29-2001, 01:20 AM
di.vo di.vo is offline
Default Help! Hard Disk attached to Disk I/O will not mount.
I have a b&w G3/450-Mac (Mac OS 9.04) with Pro Tools III (DSP Farm/ Disk I/O, Matchmaker Chip QE-Revision).
Everytime I boot my Mac with Digi Init 5.x (have tried all versions 5.0 to 5.01cs4), on the icon of the DSI appears "no disk" and the drives connected to Disk I/O-Card will not be mounted. As a consequence DAE cannot be launched, too.
When I use DSI 3.42 the Hard disk connected to the Disk I/O-Card is mounted, but that´s of no use as I need the 5.0 Versions to run on Mac OS 9.0 and with Pro Tools 5.
Does anyone know, how I can solve this problem??
Old 04-29-2001, 10:32 AM
woodywho woodywho is offline
Default Re: Help! Hard Disk attached to Disk I/O will not mount.
Greetings, if you are using a 80 pin drive get rid of it, this is a known problem. I us to have to connect my 80 pin (seagate) PT drives to the comp scsi line mount it w/ drive setup, fwb or mount digi, trash the drive, connect it back to the PT line, mount w/ digi mount. WOW!! Got rid of them for 68 pin drives w/ all my problems. If you do a search on the duc you will find old threads pertaining to this issue.
One other thing maybe a scsi accelerator might fix this!!
"Have you seen my 2 inch reel??"
HitBound Studios
ssd hard disk or classic hard disk to install pt9hd? hart07 Pro Tools HDX & HD Native Systems (Win) 4 10-21-2012 07:13 PM
DVD Data disk won't mount bryanbassett Pro Tools TDM Systems (Mac) 2 02-11-2008 05:50 PM
What happened to the Disk Mount Utility for OSX? Wheelieboy426 Pro Tools TDM Systems (Mac) 3 09-18-2003 06:59 PM
Mount PC hard disk from avid Loops Pro Tools TDM Systems (Mac) 1 03-10-2003 02:28 AM
Parallel hard disk from difference disk i/o ends? alfred Pro Tools TDM Systems (Mac) 1 11-03-1999 12:00 AM
