DC 30 slot order
What is the slot order for using a Miro card with the 001 on a MacG4.
Can I run the video off the internal drive? Do I need a SCSI drive for the audio in this case? I read in the installation tips that no SCSI cards have yet been approved. If I can use a SCSI card in the above config where would that fit in? |
Re: DC 30 slot order
Put the Digi card closest to the power-supply, the other order don't matter much.
Yes, you can run video on the internal drive, but along with multiple tracks in PT you might want to consider a SCSI card or extra IDE drive. I use an Adaptec 2940UW which is not supported, but after some tweaking, it works just fine. Dunno about the Atto-cards... use 'search' and see what others have to say. Hope this helps ------------------ Arno Peeters www.tapetv.nl |
I have 001 G4/350AGP, DC-30 and 2930 card - works great - audio on system drive and video on external SCSI.
Przemek.
http://imaginatlh.com/91709 |
So why is it mentioned on the installation tips that SCSI cards have not been approved as yet? Will it help if I partition the 27GB internal IDE drive which I have into a separate partition for audio? I am only dubbing a couple of tracks right now. Should I get another IDE drive (maybe 8GB) and instal the Mac OS on that and use the 27GB for audio?
Partitioning make things worse - head will have to jump between two partitioms all the time, I'm afraid. I tried video from system drive and basically it works, but only with high compression - but since it's reference only, I don't care. It depends on what you need - "ready" video or just reference.
Przemek.
Hi Przemek
What compression is OK if I were to run a ref picture and audio on the same drive. I used a transfer data rate of 70kb and captured at 320X240. The picture was fantastic. I can do with higher compression. What do you suggest? What is the best IDE drive to go for? |
I capture in 320 and about the same ratio. But picture is not excellent , but it's OK for reference. I do not know about drives, Barracuda or IBM seem to be a good choice (IBM is cheaper).
Przemek.
Slot order | bigfrog | Pro Tools TDM Systems (Mac) | 5 | 04-30-2008 05:27 PM |
Slot Order for PTHD5.3.1 + AV Option 5.3.1 + Magma Chassis 13-Slot + PowerMac G4 AGP | Samhein | Pro Tools TDM Systems (Mac) | 1 | 06-27-2002 11:39 AM |
Slot order? | peteri | Pro Tools TDM Systems (Mac) | 4 | 10-02-2001 01:58 PM |
Slot Order for AVOption/5-Slot Mac & Expansion Chassis | Samhein | Pro Tools TDM Systems (Mac) | 0 | 05-01-2001 09:40 AM |
Slot order in the new 4-slot Mac | Raven | Tips & Tricks | 0 | 04-03-2001 05:41 AM |
