How to change automation playlist by clicking on plugin parameter
Hello,
I know I have seen this done. Where if you already have the automation playlists for a plugin enabled you can just click on which ever parameter and it changes the playlist on the track. I have looked all thru the manual and all thru the user conference. Does anyone know what this is? Thank you very much. |
Re: How to change automation playlist by clicking on plugin parameter
By "it changes the playlist on the track" do you mean the track view changes to display the automation for the parameter you clicked on? Clicking on the control in the plug-in window? That would be fun.
Hmm. In the Keyboard Shortcuts doc, it does say under Global Keyboard Shortcuts: Change parameters on all similar channel strips: Option+applicable function (applicable functions listed below) Change parameter on all selected similar channel strips: Option+Shift+applicable function (applicable functions listed directly below) -Applicable functions: Automation mode • Monitor mode • playlist enables • record, solo and mute enables • record and solo safes • inserting plug-ins • I/O, bus, send assignment • volume/peak indicator • extend Edit or Timeline selection • track heights • clear clip meter I'm in the middle of a 45 minute bounce at the moment, but I'm gonna have to try this out when it's done. Thanks for bringing it up!
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
also, at least on tdm systems control option apple enables automation (not sure on le systems)
ihatetyping |
Right, thanks. The stuff I pasted is to do with something else entirely. Wow, this is cool. Thanks again for bringing it up, rmonday.
Thank you for that info. I am trying to use Izotope Ozone and I guess this command does not work with that plugin. It works fine with my other plugs.
It does work with LE systems by the way. I have an Mbox.
If you're referring to the Ignition Pack version of Ozone, parameters cannot be changed or automated. The full version would be needed for that.
http://www.myspace.com/philogg |
Bringing up the same automation parameter for multiple tracks | antonis | Post - Surround - Video | 7 | 05-01-2013 12:51 AM |
Glide automation to current parameter | chavernac | Pro Tools 9 | 0 | 05-14-2011 05:16 AM |
How to suspend a specific automation parameter ? | Hanswurstlsepp | ICON & C|24 | 6 | 08-13-2010 08:32 PM |
LE 7.4.2 Crashes to the desktop with TL Space size parameter change | cpdroz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-09-2009 01:06 PM |
Switching automation parameter views faster | HearInc | Tips & Tricks | 5 | 08-04-2004 03:32 PM |
