I am having MIDI Problems. Right now I'm using Battery 2 in an Instrument track to play drums and I have a click track going. I'm manually playing a straight pattern "Bass - Snare - Bass - Snare". While I'm playing I can hear the click track and I know my performance is spot on. But when I play the track back with the click track the MIDI is off beat here and there when I know it was exact. Can anyone help me with this?
- Chad |
It sounds like your grid may have been set wrong......assuming you're in 'grid' mode...which you should be for Midi stuff.....a good starting point for me is always 8th notes...if you're playing your Midi drums to weird time sigs it could also cause problems...but more than likely it's a "grid setting" issue....check your manual on how to change your grid setting's note values..........you could also try quantizing the track if you haven't already done so...this should also be a good indicator of where your problem may lie...
-Scott
ScottFB Mac OS 10.9 PT 11.1.1 Eleven Rack |
MIDI Timing PT 7.4 LE - Anyone having problems? | Donkey Kong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 117 | 10-08-2008 06:03 PM |
MIDI Timing PT 7.4 LE - Anyone having problems? | cheekypaul | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-24-2008 08:08 PM |
7.4 midi timing problems | lifer | Pro Tools TDM Systems (Win) | 2 | 11-23-2007 06:18 AM |
MIDI Timing problems with PT7.3 ?? | humbuzz | MIDI | 1 | 05-15-2007 10:53 PM |
Midi timing problems | poolhouse | Pro Tools TDM Systems (Mac) | 2 | 08-12-2006 04:20 AM |
