I have PT 7 and Reason 3.0. I'm running rewire on an Instrument track. In my Reason file I have just the Hardware Interface a Combinator with a MicroMix and three Redrums hooked into it. However, I'm not sure what device in to select in my ProTools track. Of course every device comes up and I pick the most obvious which is the Combinator, but when I play it through ProTools it gets a double voice. But when when playing back the MIDI I recorded there is no double voice. I'm not sure if it is the way I'm setting up the Reason file(which I'm thinking it is) or did I miss something in Protools. Can someone please help me out.
Did u try disabling the module input in Reason?
If Reason recognizes your keyboard, whenver you create a new module it sets a MIDI input for that module.
MacBook Pro 2.16 GHz Intel Core Duo, 2 GB of RAM, OS 10.4.11, PT 7.3.1 |
Check your Reason preferences under MIDI and make sure that you don't also have a MIDI input selected there. If you do, you'll trigger Reason both directly and via Pro Tools, resulting in the doubled voice.
i also have a question, although there is probably an obvious answer i missed. once i re-wire reason, i can hear it just fine, but how can i record it into my PT session?
degs7
You could buss the Output of the AUX track to the Input of a Audio track. filosofem
Aaron Mulqueen - 001 HD Native |
duh. thank you.
Protools 8.0.4 and Rewire Reason 5 | neorecords | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-25-2010 12:58 PM |
Reason ReWire IN ProTools LE | crazyjazzdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-30-2009 12:54 PM |
Reason Rewire with mac and Protools | teketuco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-16-2008 08:58 AM |
Buffer Setting with Rewire and protools | toadies | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-29-2003 07:31 AM |
Reason, Rewire, and Protools | jt-tujunga | Tips & Tricks | 12 | 01-14-2003 10:35 AM |
