Old 11-30-2005, 05:24 PM
e-rase e-rase is offline
Default Setting up Reason for Rewire in ProTools
I have PT 7 and Reason 3.0. I'm running rewire on an Instrument track. In my Reason file I have just the Hardware Interface a Combinator with a MicroMix and three Redrums hooked into it. However, I'm not sure what device in to select in my ProTools track. Of course every device comes up and I pick the most obvious which is the Combinator, but when I play it through ProTools it gets a double voice. But when when playing back the MIDI I recorded there is no double voice. I'm not sure if it is the way I'm setting up the Reason file(which I'm thinking it is) or did I miss something in Protools. Can someone please help me out.
Old 12-01-2005, 07:32 AM
Alex Rodriguez Alex Rodriguez is offline
Default Re: Setting up Reason for Rewire in ProTools
Did u try disabling the module input in Reason?
If Reason recognizes your keyboard, whenver you create a new module it sets a MIDI input for that module.
MacBook Pro 2.16 GHz Intel Core Duo, 2 GB of RAM, OS 10.4.11, PT 7.3.1
Old 12-01-2005, 07:49 AM
DigiTechSupt's Avatar
Check your Reason preferences under MIDI and make sure that you don't also have a MIDI input selected there. If you do, you'll trigger Reason both directly and via Pro Tools, resulting in the doubled voice.
Avid Audio Tech Support
Support FAQ
Old 01-01-2006, 06:58 PM
degs7 degs7 is offline
i also have a question, although there is probably an obvious answer i missed. once i re-wire reason, i can hear it just fine, but how can i record it into my PT session?
Old 01-01-2006, 07:30 PM
degs7
You could buss the Output of the AUX track to the Input of a Audio track.
filosofem
Aaron Mulqueen - 001 HD Native
Old 01-02-2006, 12:41 PM
duh. thank you.
Protools 8.0.4 and Rewire Reason 5 neorecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-25-2010 12:58 PM
Reason ReWire IN ProTools LE crazyjazzdrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 10-30-2009 12:54 PM
Reason Rewire with mac and Protools teketuco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-16-2008 08:58 AM
Buffer Setting with Rewire and protools toadies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-29-2003 07:31 AM
Reason, Rewire, and Protools jt-tujunga Tips & Tricks 12 01-14-2003 10:35 AM
