Old 02-27-2014, 03:20 AM
G_dog G_dog is offline
Default Behringer X32 & Pro tools 11 issue
I just loaded pro tools 11 to my Dell computer (which has Windows 7 Professional os). After connecting the X32 with the computer via USB cable and trying to boot up pro tools11, I get an error message that says "Pro Tools can't locate hardware turn on hardware and press OK". I have the Behringer x32 turned on, configured and checked the XUF card. All seems to be correct. I can't seem to figure out what I'm doing wrong or if I have a software issue. PLease help.
Thanks
Old 02-27-2014, 07:03 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Behringer X32 & Pro tools 11 issue
Thanks
So is the X32 the audio device? have you installed the drivers for the X32?
Im not even sure the X32 can be an audio interface personally but will assume it can be.
in the setup>playback engine. is the X32 assigned as the audio engine/interface
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-27-2014, 12:19 PM
To expound a little on what Chris offered, try holding the "N" key while opening Pro Tools as that should take you directly to the audio engine page so you can select the X32 to be the audio engine(without the driver, it likely will not be available)
Old 02-27-2014, 12:28 PM
feliponk's Avatar
feliponk feliponk is offline
Hi: take a look here.
http://www.behringer.com/EN/Products...oftwareContent
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Catalina | Windows 11 Pro | ProTools HD 2022.x | Merging HAPI ADA8 | UAD Quad PCIe | Avid Artist Mix | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 02-28-2014, 07:11 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Let us know.
It reads as a nice control and mixer i/o device.
Pro Tools 10 and Behringer FCA202 ... anyone using? NHH macOS 1 10-02-2012 11:57 PM
Behringer ada8000 major Delay issue alarmstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-05-2012 02:30 PM
Pro Tools 9 and Behringer Mixer Bos Def Pro Tools 9 8 12-24-2010 10:29 PM
Behringer DDX3216 and Pro Tools Pro Toolz LE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-26-2005 10:08 PM
behringer mx9000,behringer mx3282A,mackie 24/8buss JOAN ROSALES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-03-2004 12:21 AM
