Old SC instrs referencing SDI samples
I have recently transferred my SC files to a new system (the previous one was NuBus, this is a PCI system w/the latest SC Editor version). I've had some problems opening these older files before, but this is one that I can't seem to get around; when opening an instrument that references a sample created in Sound Designer I (I've got some old samples), the SC Editor crashes when it 'finds' the samples. I've tried it several times, and can't get it to work. The NuBus Editor will 'find' these samples w/o crashing. I can make a new instrument with the old samples on the PCI system; I just can't use my old instruments. Unfortunately, there is no way to find the sample mappings of these instruments.
I'm using a G3 266, System 8.1, SC Editor 2.1.1. The SC card has a TDM piggyback thingy. |
Re: Old SC instrs referencing SDI samples
If you trigger the file searching with PCI-made files (just move some of the referenced sounds around) does it crash?
I could not reproduce this here and I'm trying to figure out what else could be going wrong for you. BTW, what sample cell editor versions are you using? I had 2.1.1 on both systems. -bm- |
Better cross-referencing of info | Top Jimmy | General Discussion | 0 | 01-27-2009 03:31 PM |
basic virt instrs for PT LE | hojocola | MIDI | 0 | 01-04-2005 05:31 PM |
referencing CDs through mbox | bannerj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-22-2004 01:06 PM |
cd referencing a PT mix | Dr. J | Tips & Tricks | 9 | 03-23-2001 09:40 PM |
Referencing Movie Bummer | COCO | Pro Tools TDM Systems (Mac) | 14 | 01-05-2001 09:25 PM |
