Old 02-02-2002, 10:56 AM
Felix Felix is offline
Default a good idea to start sessions in .wav from now on?
for those who choose to stay with pre-HD systems, would it be wise to start sessions in .wav instead of the default of SDII?
Old 02-02-2002, 01:43 PM
Kev Kev is offline
Default Re: a good idea to start sessions in .wav from now on?
I am doing some tests now to be sure about compatibilities .... with the Digi001 system I have.
BUT I am thinking of using .wav on the next session.
Should I be ticking that 'AES/EBU wave compatibility ' box???
Old 02-02-2002, 02:05 PM
Hardnox Hardnox is offline
Won't SDII's open in HD? I was told by digi that all Mix sessions are compatible as long as plug-ins are upgraded.
www.hardnoxproductions.com
Old 02-02-2002, 03:21 PM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Hardnox:
Won't SDII's open in HD? I was told by digi that all Mix sessions are compatible as long as plug-ins are upgraded.<HR></BLOCKQUOTE>
not sure, but i think when they say compatable, they mean after HD converts all files to .wav, just like with Windows.
Old 02-02-2002, 03:28 PM
DigiTechSupt's Avatar
Yes, SDII files will open on an HD system, as will any session created on a Mix system, but SDII is limited to 48k.
If you want to record at any sample rate higher than 48k you will have to use either AIFF or .WAV file formats, SDII is not an option.
Jon Connolly
Digidesign Product Specialist
Avid Audio Tech Support
Support FAQ
Old 02-02-2002, 03:48 PM
Paul Greyson Paul Greyson is offline
WAV is probably going to be your best option in the long run. There's more standards work going on around WAV (and pretty much none around SDII.)
Paul Greyson
Digidesign Engineering
Old 02-02-2002, 04:47 PM
audiaudio audiaudio is offline
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Jon Connolly, DigiTechSupt:
Yes, SDII files will open on an HD system, as will any session created on a Mix system, but SDII is limited to 48k.<HR></BLOCKQUOTE>
Jon Connolly, when you write, "SDII is limited to 48k," you seem to be saying 48k only--that is, no 44.1, 96, or any rate other than 48.
Did you mean "limited to a maximum of 48k"--in other words, 44.1 and 48k?
Please clarify.
Thanks.
 iMac i7 2020 Monterey 16GB HD Native Thunderbolt
Old 02-02-2002, 10:20 PM
Jeff Hodges Jeff Hodges is offline
I read that you can run 44.1 or 48 SDII's on HD (so up to 48)
Paul - do we lose anything going .wav? Like, is .wav larger filesize, more difficult to deal with etc etc for PT or is it better, the same, what?
"J.Ho"
www.caffeinetrax.com
Old 02-03-2002, 06:52 PM
Nope. Really no downside to going with .wav except compatibility with pre 5.1 Pro Tools (which could not play .wav native.)
Paul Greyson
Old 02-03-2002, 06:56 PM
JamerJ JamerJ is offline
These are good points to take into consideration Digi! Thanks!
[img]images/icons/rolleyes.gif[/img] [img]images/icons/shocked.gif[/img] [img]images/icons/rolleyes.gif[/img] [img]images/icons/shocked.gif[/img] [img]images/icons/rolleyes.gif[/img]
Jim
JSM Music NY/LA
An idea... implement auto "write to end/start/..." GVDB ProControl, Control|24, Command|8 9 08-26-2004 02:53 PM
Good Idea/ Bad Idea Slade General Discussion 0 07-24-2003 07:30 PM
onboard sound, good idea/bad idea?! sampb7 Digidesign Hardware & Software 1 02-22-2003 02:44 AM
Is this a good idea? Larryboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-14-2002 05:56 AM
is this a good idea whosmatt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 09-08-2001 09:16 AM
