Old 06-25-2012, 10:11 AM
Fitzgrade Fitzgrade is offline
Default Program change
When i am using my virus ti and have midi clips playback a preset i pick out after it loops back to the first bar it changes back to the default patch i know its got to do with program change but i cant seem to figure out how to turn it off so the preset i want to use stays?? Any help plz
Old 07-04-2012, 03:30 AM
Exclamation Re: Program change
I cant understand why after the 2nd time in trying to get help on here i just keep getting blanked i have a very small but very iritating problem while trying to use alot of vsts. As you see by the above post some vst that i always use usually in other d.a.w,s and ones that ive grown used to using all the time are not working as they should and i think its because of program information or maybe the midi i import has some program info in it that uses a certain type of sound NOT A GLUE OTHERWISE really this should not be that hard to answer for a expierenced user. PLZ PLZ PLZ
Old 07-07-2012, 08:15 AM
Heeeeeeeeeeeeeeeeeeeeelllllllllllllllllppppppppppp p meeeeeeeeeeeeeeeeeee!!!!!!!!!!!!!
Old 08-05-2012, 09:47 AM
Default Re: Program change
If i could please please please get sum help on this ive asked around no1 knows what im doing wrong or need to do. Thanks
Own Program Change Map Martin.Jirsak Pro Tools 10 0 05-02-2012 07:28 AM
PT 9 crash with program change toronjaasesina macOS 0 12-18-2010 08:38 AM
Mdi program change mksnz MIDI 0 07-03-2005 09:42 AM
midi program change porkipine MIDI 3 05-14-2005 04:52 AM
Midi program change on the fly GaryGarris Pro Tools TDM Systems (Mac) 5 11-16-2000 10:20 AM
