Old 02-06-2011, 11:47 AM
tommyknocker tommyknocker is offline
Unhappy Unable to locate hardware...003rack+
Using LE 8.0 for almost 2 yrs. now. Had computer built(gave computer guy 3/4 in. guide that came with system) and really had no problems except the "unable to locate hardware" every now and then. Solved problem before by "hot wiring", switching firewire cord on back of 003 rack to other firewire input, clicking "ok" and LE opens........
It will not open now 1) have tried all troubleshooting and optimization, reboot, reinstall drivers,blahblahblah. My question is this: before I sandra report and send it to you guys, we think the ports in the back of the 003 are blown, therfore shipping out to authorized facility,etc..... Now we have taken the 003 out of rack and tried hooking it up to another computer and the device manager did not recognize any hardware, leading us to believe the ports are bad.
2) Two local music shops that sell pro-tools gear have 2 different answers: one agrees with us and the other says the proprietory license in the 003 WILL NOT let any other computer recognize this (003) hardware without having the software installed?
Which is right......cuz I'm all for working thru this problem without shipping the rack out first. Thanks in advance
Old 02-06-2011, 11:18 PM
Default Re: Unable to locate hardware...003rack+
Well, if you hot-patched the firewire cable(unplug and replug while things are powered up) you may have fried the firewire board in the 003. I have also had firewire cables die for no apparent reason(so do try another cable). If you are not getting the "New Hardware Found" message when patching to another computer, then it is likely the cable or the firewire board(which could cost upwards of $300 to fix).
Old 02-07-2011, 10:32 AM
thanks albee: and I would send that to authorized repair facility? Will check diff cords first though(although tried a few already). When I get it back will try to solve initial problem?
Old 02-07-2011, 10:37 AM
sw rec sw rec is offline
Yes, turn EVERYTHING OFF first before swapping firewire cables.
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned o MerryD Pro Tools SE and Essential (Win) 8 08-02-2012 12:59 AM
Unable to locate Digidesign hardware. Make sure hardware is connected and turned on. qillster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-09-2011 06:49 PM
Unable to locate M-Audio Hardware. Make sure your hardware is connected and turned on ytass Pro Tools M-Powered (Win) 4 11-25-2009 12:49 PM
unable to locate m-audio hardware. make sure your hardware is..works fine in ableton? pein Pro Tools M-Powered (Win) 2 10-07-2009 12:01 AM
unable to locate M-Audio hardware. Make sure your hardware is connected and turned on joskraus Pro Tools M-Powered (Win) 13 05-13-2009 09:05 AM
