Old 04-25-2010, 03:33 AM
Brad Harris Brad Harris is offline
Default Routing Monitor Stereo through Plugins ...
Recently watched the webinar Advanced Topics, Power User Tips & Tricks https://admin.na5.acrobat.com/_a7697...&pbMode=normal
And I'm having a slight problem in the offline editor (2.8.1) of patching the Stereo Monitor through the Plug Ins to route to an input processing channel. What the issue is that when you assign the input to a Plugin, there is no option to route the output of the plugin (Single Band Stereo EQ).
This doesn't happen with the Mono monitor, and patching of any other stereo source works as well.
Or am I missing another way to route an output into an input without leaving the desk?
Old 04-27-2010, 12:56 PM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: Routing Monitor Stereo through Plugins ...
Hi Brad,
It's possible to route the monitor bus to a plug-in (such as an analysis plug-in), but its return can not be patched to an input channel because in many cases this could cause an immediate feedback loop.
Instead, route the monitor output to a physical output (such as the 2-Tr analog or digital outs) and bring it back in as a normal input. Yes, it takes a bit of thought to get this right, but the chances of a speaker- or ear-blowing feedback loop are greatly reduced.
Sheldon
Re-routing stereo for 5.1 idris Post - Surround - Video 4 11-05-2012 01:50 AM
Routing to give a stereo group a stereo plugin on the VENUE plus AES EBU uses somtech VENUE Live Sound Systems 5 05-19-2012 06:43 AM
Stereo Aux not Routing to Master blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-15-2009 07:20 AM
Mixdown routing for 5.1 AND Stereo in 1 pass Peter Groom Pro Tools TDM Systems (Mac) 2 08-11-2009 12:15 AM
TL Space True Stereo Routing Issue - HELP innenhofstudios Pro Tools TDM Systems (Mac) 2 02-18-2009 08:27 AM
