Hi
When i mixdown my .1 mix soon, i want to make 5.1 discreet mixes and a stereo mix at the same time. Is this my best routing All contribution tracks to 5.1 group & Stereo group by ctrl click the routing window.The 5.1 group into a 5.1 aux, then out to a 5.1 audio track. The stereo group is routed to stereo aux and then to new stereo goup and into stereo audio track. Is this the best way, or am i missing something obvious Peter |
Typical 5.1 down-mixing is a little different than that. Try this first.
Create a 5.1 SUB making the individual channels available as two stereo (L/R, Ls/Rs) and two mono (C, Lfe). Take the complete 5.1 sub to a new 5.1 TRACK with its output feeding your 5.1 monitors. At the same time create a STEREO SUB. Create a stereo AUX with input L/R from your 5.1 SUB to the STEREO SUB. Create a mono AUX with input C from the 5.1 sub to the STEREO SUB. Because you're taking a mono track and 'panning' it to L/R it will be down the proper 3dB. Create another stereo AUX with input Ls/Rs from your 5.1 SUB to the STEREO SUB. The .1 channel is not used. Create a new STEREO TRACK with the STEREO SUB as its input and output to L/R monitors. This will give you a discrete 5.1 mix to your 5.1 track as well as a proper downmix with some adjustability, if you want it, using the L/R, C and Ls/Rs aux faders to your stereo track. As you work, you may need to trim your surround level down a bit, but this setup gives you that flexibility. BTW, all of your tracks may be assigned to the 5.1 buss with surround panning or discrete L/R, C or Ls/Rs this way. I'd use an AUX SEND for the Lfe track if necessary.
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
HI Eric
Thanks so much for that. Once again good advice from across the pond in an instant! Peter |
Re-routing stereo for 5.1 | idris | Post - Surround - Video | 4 | 11-05-2012 01:50 AM |
how do i mixdown to stereo? | jdphillips73 | Pro Tools 10 | 2 | 10-21-2012 07:53 PM |
Routing to give a stereo group a stereo plugin on the VENUE plus AES EBU uses | somtech | VENUE Live Sound Systems | 5 | 05-19-2012 06:43 AM |
5.1 Mixdown to Stereo Bounce | stealth_162 | Post - Surround - Video | 11 | 02-04-2006 02:08 PM |
Stereo Mixdown on AudioVision menu | Kjetil | Post - Surround - Video | 0 | 03-01-2001 10:23 AM |
