Old 11-10-2008, 05:10 PM
Dopamine Dopamine is offline
Default Mute Frees Assigned Voice - question
Any reason NOT to have this enabled?
Old 11-11-2008, 12:17 AM
poly915 poly915 is offline
Default Re: Mute Frees Assigned Voice - question
This option is only useful if you you are setting explicit voices to tracks. If you set several tracks to the same voice, this option will allow you to "cascade" the available voice to each track as similarly voiced tracks are muted/unmuted.
If you are running all your tracks as 'dynamic', you will never need to use the "Mute Frees Assigned Voice" option.
Old 11-11-2008, 02:52 AM
Muting will be slightly slower with this option enabled... The only time I enable it is when using voice stealing (comping).
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Mute Frees Assigned Voice save bug RIO Pro Tools TDM Systems (Mac) 0 08-09-2006 12:10 PM
> HD - Audio leak thru track w/ no voice assigned Howardk Pro Tools TDM Systems (Mac) 0 02-22-2006 03:00 PM
Why does "mute frees assigned voices" go away? Frank Kruse Post - Surround - Video 2 09-19-2005 10:41 AM
Mute Frees Voice Please tha k man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-23-2003 06:24 AM
Saving dsp resources... Mute frees voice? Kris Tips & Tricks 2 04-12-2000 07:48 PM
